Cloning an API
To improve API creation efficiency, you can clone an API with a custom name and path.
Policies bound to an API cannot be cloned and can only be manually bound to the new API.
You have created an API. If no API is available, create one by referring to Creating an API.
- Go to the APIG console.
 - Select a dedicated gateway at the top of the navigation pane.
- In the navigation pane, choose API Management > API Groups.
 - Click a group name.
 - On the APIs tab, choose More > Clone.
 - Set the API name and path, and click OK.
Follow-Up Operations
After cloning an API, verify it by following the procedure in Debugging an API.
