Help Center/
API Gateway/
User Guide (ME-Abu Dhabi Region)/
Gateway Management/
Viewing or Modifying Gateway Information
Updated on 2023-05-09 GMT+08:00
You can view and modify the configuration of your gateways on the console.
- In the navigation pane, choose Gateways.
- Click Access Console or the name of the target gateway.
- On the Gateway Information tab, view or modify the configuration of the gateway.
Parent topic: Gateway Management
