Updated on 2025-01-09 GMT+08:00
ALTER COLUMN
Function
This syntax modifies the current column properties, including column comments and null constraints. Currently, it does not support modifying column types or column positions.
Precautions
  • Modifying column types is currently not supported.
  • Modifying the order of existing columns is currently not supported.
  • Adding columns in a specified order is currently not supported.
Syntax
ALTER TABLE Table name ALTER
[COLUMN] col_name
[COMMENT] col_comment
Parameter Description
Table 1 ALTER COLUMN parameters
tableName
Table name.
col_name
Name of the column to be altered.
column_type
Type of the target column.
col_comment
Column comment.
column_name
New position to place the target column. For example, AFTER column_name indicates that the target column is placed after column_name.
Required Permissions
  • SQL permissions
Table 2 Permissions required for executing ALTER TABLE
Permission Description
ALTER permission on a table
  • Fine-grained permission: dli:table:alter
  • Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Example
  • Altering other attributes
    ALTER TABLE table1 ALTER COLUMN col_a DROP NOT NULL
    ALTER TABLE table1 ALTER COLUMN col_a COMMENT 'new comment'
Response
You can run the DESCRIBE command to view the modified column.
