INSERT
Function
This command inserts SELECT query results to a Delta table.
Syntax
Append mode:
INSERT INTO [database_name.]table_name|DELTA.`obs://bucket_name/tbl_path`
select query;
Overwrite mode:
INSERT OVERWRITE [database_name.]table_name|DELTA.`obs://bucket_name/tbl_path`
select query;
Parameter Description
Parameter |
Description |
database_name |
Name of the database, consisting of letters, numbers, and underscores (_) |
table_name |
Name of the table in the database, consisting of letters, numbers, and underscores (_) |
bucket_name |
OBS bucket name |
tbl_path |
Storage location of the Delta table in the OBS bucket |
select query |
Query statement |
Required Permissions
- SQL permissions
Permission Description |
INSERT_INTO_TABLE permission on a table |
- Fine-grained permission: dli:table:insertIntoTable
- Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Example
insert into delta_table0 values(1, 'a1', 20); insert into delta_table0 select 1, 'a1', 20; insert into test_delta_parts1 PARTITION(dt) select id,name,dt from test_delta1; -- insert overwrite table insert overwrite table delta_table0 select 1, 'a1', 20;
System Response
Displays whether the task is successfully executed in the execution history or job list.
