DROP CONSTRAINT
Function
This command deletes a CHECK constraint.
Syntax
ALTER TABLE [database_name.]table_name|DELTA.`obs://bucket_name/tbl_path`
DROP CONSTRAINT constraint_name
Parameter Description
Parameter |
Description |
database_name |
Name of the database, consisting of letters, numbers, and underscores (_) |
table_name |
Name of the table in the database, consisting of letters, numbers, and underscores (_) |
bucket_name |
OBS bucket name |
tbl_path |
Storage location of the Delta table in the OBS bucket |
constraint_name |
Constraint name |
Required Permissions
- SQL permissions
Permission Description |
ALTER permission on a table |
- Fine-grained permission: dli:table:alter
- Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Example
alter table delta_table0 drop constraint const_price; alter table delta.`obs://bucket1/dbgms/h0` drop constraint const_id;
System Response
Displays whether the task is successfully executed in the execution history or job list.
