Restoring a Delta Table to an Earlier State
Syntax
Restore a Delta table to the state at a specific point in time:
RESTORE [TABLE] [database_name.]table_name|DELTA.`obs_path`
[TO] TIMESTAMP AS OF timestamp_expression
Restore a Delta table to the state at a specific historical version:
[TO] VERSION AS OF version_code
Parameter Description
| Parameter | Description |
| database_name | Name of the database, consisting of letters, numbers, and underscores (_) |
| table_name | Name of the table in the database, consisting of letters, numbers, and underscores (_) |
| obs_path | OBS path, indicating the storage location of the Delta table |
| timestamp_expression | Timestamp, which cannot be later than the current time, formatted as yyyy-MM-ddTHH:mm:ss.SSS |
| version_code | Version number in the query result in Viewing History Operation Records of a Delta Table |
Example
RESTORE delta_table0 TO TIMESTAMP AS OF '2020-10-18T22:15:12.013Z'; RESTORE delta.`obs://bucket_name/db0/delta_table0` VERSION AS OF 2;
