Updated on 2026-03-17 GMT+08:00
Adding Tags to a Bucket
When creating a bucket, you can add tags to it. For details, see Creating a Bucket. You can also add tags to a bucket after it has been created. This section describes how to add tags to an existing bucket.
  1. In the bucket list of OBS Console, click the required bucket to go to the Overview page.
  2. In the navigation pane, choose Basic Configurations > Tagging.
  3. Click Add Tag. The Add Tag dialog box is displayed.
  4. Set the key and value based on Table 1.
    Table 1 Parameter description
    Tag key
    Key of a tag. Tag keys for the same bucket must be unique. You can customize tags or select the ones predefined on TMS.
    A tag key:
    • Must contain 1 to 36 characters and be case sensitive.
    • Cannot start or end with a space or contain the following characters: =*<>\,|/
    Tag value
    Value of a tag. A tag value can be repetitive or left blank.
    A tag value:
    • Can contain 0 to 43 characters and must be case sensitive.
    • Cannot contain the following characters: =*<>\,|/
  5. Click OK.
    It takes approximately 3 minutes for the tag to take effect.
Related Operations
In the tag list, click Edit to change the tag value or click Delete to remove the tag.
