Updated on 2026-01-16 GMT+08:00
Monitored OBS Metrics
Functions
This section defines the namespace, list, and dimensions of monitoring metrics reported by OBS to Cloud Eye. You can use the management console or APIs provided by Cloud Eye to search for monitoring metrics and alarms generated by OBS.
Namespace
SYS.OBS
Monitoring Metrics
Metric ID
Metric
Value Range
Dimension
Monitoring Period (Original Metric)
download_bytes
Bytes Downloaded
Specifies the response bytes of all download requests made to all buckets in a region, including bytes in HTTP entity bodies.
Unit: byte
≥ 0 bytes
bucket_name
5 min
upload_bytes
Bytes Uploaded
Specifies the bytes of all upload requests made to all buckets in a region, including bytes in HTTP entity bodies.
Unit: byte
≥ 0 bytes
bucket_name
5 min
get_request_count
GET Requests
Specifies the number of GET, HEAD, or OPTIONS requests made to all buckets and objects in the buckets of a region.
Unit: count
≥ 0 counts
bucket_name
5 min
put_request_count
PUT Requests
Specifies the number of PUT, POST, and DELETE requests made to all buckets and objects in the buckets of a region.
Unit: count
≥ 0 counts
bucket_name
5 min
first_byte_latency
First Byte Download Delay
Specifies the average time from receiving a GET, HEAD, or OPTIONS request to the time that the system starts to respond in a measurement period.
Unit: ms
≥ 0 ms
bucket_name
5 min
request_count_4xx
4xx Errors
Number of server responses with 4xx status codes
Unit: count
≥ 0 counts
bucket_name
5 min
request_count_5xx
5xx Errors
Number of server responses with 5xx status codes
Unit: count
≥ 0 counts
bucket_name
5 min
Dimensions
Table 1 Dimensions
Key
Value
tenant_id
User dimension. The value is a domain ID.
bucket_name
Bucket dimension. The value is the bucket name.
bucket_name,api_name
API dimension. For details about the value, see Table 2.
bucket_name,domain_name
Domain name dimension. The value is the domain name of the bucket to be accessed.
  • tenant_id,http_code
  • bucket_name,http_code
  • bucket_name,api_name,http_code
HTTP status code dimension. For details about the values, see Table 3.
Request APIs
The following table lists the APIs supported by the Bucket_Name - API Name dimension in Table 1.
Table 2 Request APIs
ID
Name
LIST.BUCKETS
Listing Buckets
PUT.BUCKET
Creating a Bucket
LIST.BUCKET.OBJECTS
Listing Objects in a Bucket
LIST.BUCKET.OBJECTVERSIONS
Listing Objects in a Bucket (Versioning)
HEAD.BUCKET
Obtaining Bucket Metadata
GET.BUCKET.LOCATION
Obtaining Bucket Location
LIST.BUCKET.UPLOADS
Listing Multipart Uploads
POST.OBJECT.MULTIDELETE
Batch Deleting Objects
LIST.BUCKET.OBJECTS
Listing Objects
POST.OBJECT
Uploading Objects - POST
PUT.PART
Uploading Parts
PUT.PART.COPY
Copying Parts
DELETE.UPLOAD
Canceling a Part
LIST.OBJECT.UPLOAD
Listing Uploaded Parts of an Object
POST.UPLOAD.COMPLETE
Completing a Multipart Upload
POST.UPLOAD.INIT
Initiating a Multipart Upload
PUT.OBJECT
Uploading Objects
APPEND.OBJECT
Appending an Object
PUT.OBJECT.COPY
Copying an Object
DELETE.OBJECT
Deleting an Object
GET.OBJECT
Downloading an Object
HEAD.OBJECT
Heading objects
Listing Object Versions
POST.OBJECT.RESTORE
Restoring an Object
PUT.OBJECT.METADATA
Modifying Object Metadata
HTTP Status Codes
The following table lists the HTTP status codes supported by the User - HTTP Status Code, Bucket_Name - API Name - HTTP Status Code, and Bucket_Name - HTTP Status Code dimensions in Table 1.
Table 3 HTTP status codes
HTTP Status Code
400
Incorrect request packet format.
401
Failed to authenticate and authorize.
403
Insufficient permission, access denied, limited MimeType, file type not allowed, or others
404
The requested resource does not exist.
405
The specified method is not allowed against the requested resource.
406
CRC32 check failed for the uploaded data.
413
Incorrect size of the uploaded object.
579
The object is successfully uploaded, but the callback fails.
599
The server fails to operate.
612
The specified resource does not exist or has been deleted.
614
The target resources already exist.
701
The block expires, the segments are discontinuous, the total block size does not match the object size, or others.
