Updated on 2023-04-10 GMT+08:00
DevOps and CI/CD
Application Scenario
You may receive a lot feedback and requirements for your apps or services. You may want to boost user experience with new features. Continuous integration (CI) and delivery (CD) can help. CI/CD automates builds, tests, and merges, making app delivery faster.
Benefits
CCE works with SWR to support DevOps and CI/CD. A pipeline automates coding, image build, grayscale release, and deployment based on code sources. Existing CI/CD systems can connect to CCE to containerize legacy applications.
Advantages
  • Efficient process
    Reduces scripting workload by more than 80% through streamlined processes.
  • Flexible integration
    Provides various APIs to integrate with existing CI/CD systems for in-depth customization.
  • High performance
    Enables flexible scheduling with a containerized architecture.
Related Services
Software Repository for Container (SWR), Object Storage Service (OBS), Virtual Private Network (VPN)
Figure 1 How DevOps works
