Updated on 2023-04-10 GMT+08:00
Mappings Between CCE and Kubernetes Terms
Kubernetes (K8s) is an open-source system for automating deployment, scaling, and management of container clusters. It is a container orchestration tool and a leading solution based on the distributed architecture of the container technology. Kubernetes is built on the open-source Docker technology that automates deployment, resource scheduling, service discovery, and dynamic scaling of containerized applications.
This topic describes the mappings between CCE and Kubernetes terms.
Table 1 Mappings between CCE and Kubernetes terms
CCE
Kubernetes
Cluster
Cluster
Node
Node
Node pool
NodePool
Container
Container
Namespace
Namespace
Deployment
Deployment
StatefulSet
StatefulSet
DaemonSet
DaemonSet
Job
Job
Cron job
CronJob
Pod
Pod
Service
Service
ClusterIP
Cluster IP
NodePort
NodePort
LoadBalancer
LoadBalancer
Layer-7 load balancing (ingress)
Ingress
Network policy
NetworkPolicy
Chart
Template
ConfigMap
ConfigMap
Secret
Secret
Label
Label
Label selector
LabelSelector
Annotation
Annotation
Volume
PersistentVolume
PersistentVolumeClaim
Auto scaling
HPA
Node affinity
NodeAffinity
Node anti-affinity
NodeAntiAffinity
Pod affinity
PodAffinity
Pod anti-affinity
PodAntiAffinity
Webhook
Webhook
Endpoint
Endpoint
Quota
Resource Quota
Resource limit
Limit Range
