What Should I Do If a Node Pool Scale-Out Fails?
Fault Locating
Locate the fault based on the events of the failure to scale out a node pool, as shown in Table 1.
Event |
Possible Cause |
Reference |
...call fsp to query keypair fail, error code : Ecs.0314, reason is : the keypair *** does not match the user_id ***... |
The possible causes are as follows:
Failed to Obtain the Key Pair Used for Logging In to a Node Pool |
{"error":{"message":"encrypted key id [***] is invalid.","code":"Ecs.0912"}} |
Security group [*****] not found |
This issue can arise in the following scenarios:
If a node pool scale-out fails, the event contains Ecs.0314. This error code indicates that the key pair used for logging in to the node pool cannot be obtained, which results in the creation failure of a new ECS.
- The key pair selected for logging in to the node pool has been deleted.
- The key pair selected for logging in to the node pool is a private one which cannot be used by the current user to log in to the node pool and create nodes in the node pool.
Solution:
- If the scale-out fails due to the first cause, you can create a key pair and then create a node pool which can be logged in to using this key pair.
- If the scale-out fails due to the second cause, only the user who created the private key pair can scale out the node pool. You can use another key pair when creating a new node pool.
Invalid KMS Key ID
When a node pool fails to be expanded, the reported event contains Ecs.0912.
- The KMS key ID entered during node pool creation does not exist.
- The KMS key ID entered during node pool creation is the key of another user, but the user has not authorized you.
Solution:
- If the scale-out fails due to the first cause, ensure that the entered key ID exists.
- If the scale-out fails due to second cause, use the ID of the shared key that has been authorized to you.
The Security Group Specified by the Node Pool Deleted
When a node pool fails to be expanded, the event contains the following information:
- Scenarios 1: A custom security group is set up for the node pool but gets deleted, so the node pool scale-out fails.
- Scenarios 2: No custom security group is configured for the node pool and the default security group is deleted, so the node pool scale-out fails.
Solution:
- Scenario 1: Update the security group specified by the customSecurityGroups field by calling the API for updating a node pool.
- Scenario 2: Log in to the CCE console and change the default node security group on the Settings page of the cluster. The new node security group must meet the communication rules of the cluster ports. For details, see How Can I Configure a Security Group Rule for a Cluster?
