How Can I Locate Faults Using an Exit Code?
When a container fails to be started or terminated, the exit code is recorded by Kubernetes events to report the cause. This section describes how to locate faults using an exit code.
Viewing an Exit Code
You can use kubectl to connect to the cluster and run the following command to check the pod:
kubectl describe pod {pod name}
Containers:
container-1:
Container ID: ...
Image: ...
Image ID: ...
Ports: ...
Host Ports: ...
Args: ...
State: Running
Started: Sat, 28 Jan 2023 09:06:53 +0000
Last State: Terminated
Reason: Error
Exit Code: 255
Started: Sat, 28 Jan 2023 09:01:33 +0000
Finished: Sat, 28 Jan 2023 09:05:11 +0000
Ready: True
Restart Count: 1
The exit code ranges from 0 to 255.
- If the exit code is 0, the container exits normally.
- Generally, if the abnormal exit is caused by the program, the exit code ranges from 1 to 128. In special scenarios, the exit code ranges from 129 to 255.
- When a program exits due to external interrupts, the exit code ranges from 129 to 255. When the operating system sends an interrupt signal to the program, the exist code is the interrupt signal value plus 128. For example, if the interrupt signal value of SIGKILL is 9, the exit status code is 137 (9 + 128).
- If the exist code is not in the range of 0 to 255, for example, exit(-1), the exit code is automatically converted to a value that is within this range.
If the exist code is a positive number, the conversion formula is as follows:
code % 256
If the exit code is a negative number, the conversion formula is as follows:
256 - (|code| % 256)
For details, see Exit Codes With Special Meanings.
Common Exit Codes
Exit Code |
Name |
Description |
0 |
Normal exit |
The container exits normally. This status code does not always indicate that an exception occurs. When there is no process in the container, it may also be displayed. |
1 |
Common program error |
There are many causes for this exception, most of which are caused by the program. You need to further locate the cause through container logs. For example, this error occurs when an x86 image is running on an Arm node. |
125 |
The container is not running. |
The possible causes are as follows:
126 |
Command calling error |
The command called in the image cannot be executed. For example, the file permission is insufficient or the file cannot be executed. |
127 |
The file or directory cannot be found. |
The file or directory specified in the image cannot be found. |
128 |
Invalid exit parameter |
The container exits but no valid exit code is provided. There are multiple possible causes. You need to further locate the cause. For example, an application running on the containerd node attempts to call the docker command. |
137 |
Immediate termination (SIGKILL) |
The program is terminated by the SIGKILL signal. The common causes are as follows:
139 |
Segmentation error (SIGSEGV) |
The container receives the SIGSEGV signal from the OS because the container attempts to access an unauthorized memory location. |
143 |
Graceful termination (SIGTERM) |
The container is correctly closed as instructed by the host. Generally, this exit code 143 does not require troubleshooting. |
255 |
The exit code is out of range. |
The container exit code is out of range. For example, exit(-1) may be used for abnormal exit, and -1 is automatically converted to 255. Further troubleshooting is required. |
Linux Standard Interrupt Signals
You can run the kill -l command to view the signals and corresponding values in the Linux OS.
Signal |
Value |
Action |
Commit |
SIGHUP |
1 |
Term |
Sent when the user terminal connection (normal or abnormal) ends. |
SIGINT |
2 |
Term |
Program termination signal, which is sent by the terminal by pressing Ctrl+C. |
SIGQUIT |
3 |
Core |
Similar to SIGINT, the exit command is sent by the terminal. Generally, the exit command is controlled by pressing Ctrl+\. |
SIGILL |
4 |
Core |
Invalid instruction, usually because an error occurs in the executable file. |
SIGABRT |
6 |
Core |
Signal generated when the abort function is invoked. The process ends abnormally. |
SIGFPE |
8 |
Core |
A floating-point arithmetic error occurs. Other arithmetic errors such as divisor 0 also occur. |
SIGKILL |
9 |
Term |
Any process is terminated. |
SIGSEGV |
11 |
Core |
Attempt to access an unauthorized memory location. |
SIGPIPE |
13 |
Term |
The pipe is disconnected. |
SIGALRM |
14 |
Term |
Indicates clock timing. |
SIGTERM |
15 |
Term |
Process end signal, which is usually the normal exit of the program. |
SIGUSR1 |
10 |
Term |
This is a user-defined signal in applications. |
SIGUSR2 |
12 |
Term |
SIGCHLD |
17 |
Ign |
This signal is generated when a subprocess ends or is interrupted. |
SIGCONT |
18 |
Cont |
Resume a stopped process. |
SIGSTOP |
19 |
Stop |
Suspend the execution of a process. |
SIGTSTP |
20 |
Stop |
Stop a process. |
SIGTTIN |
21 |
Stop |
The background process reads the input value from the terminal. |
SIGTTOU |
22 |
Stop |
The background process reads the output value from the terminal. |
