Configuring Cluster Security Group Rules
CCE is a universal container platform. Its default security group rules apply to common scenarios. When a cluster is created, a security group is automatically created for the master node and worker node, separately. The security group name of the master node is {Cluster name}-cce-control-{Random ID}, and the security group name of the worker node is {Cluster name}-cce-node-{Random ID}. If a CCE Turbo cluster is used, an additional ENI security group named {Cluster name}-cce-eni-{Random ID} will be created.
You can log in to the management console, choose Service List > Networking > Virtual Private Cloud. On the page displayed, choose Access Control > Security Groups in the navigation pane, locate the security group of the cluster, and modify the security group rules as required.
The default security group rules of the clusters using different networks are as follows:
- Security Group Rules of a Cluster Using a VPC Network
- Security Group Rules of a Cluster Using the Tunnel Network
- Security Group Rules of a CCE Turbo Cluster Using the Cloud Native Network 2.0
![](https://support.huaweicloud.com/intl/en-us/ae-ad-1-usermanual-cce/public_sys-resources/notice_3.0-en-us.png)
- Modifying or deleting security group rules may affect cluster running. Exercise caution when performing this operation. If you need to modify security group rules, do not modify the rules of the port on which CCE running depends.
- When adding a new security group rule to a cluster, ensure that the new rule does not conflict with the original rules. Otherwise, the original rules may become invalid, affecting the cluster running.
Security group of a worker node
A security group named {Cluster name}-cce-node-{Random ID} is automatically created for each worker node. For details about the default ports, see Table 1.
Direction |
Port |
Default Source Address |
Description |
Modifiable |
Modification Suggestion |
Inbound rules |
All UDP ports |
VPC CIDR block |
Used for mutual access between worker nodes and between a worker node and a master node. |
No |
N/A |
All TCP ports |
All ICMP ports |
Security group of the master node |
Used for the master node to access worker nodes. |
No |
N/A |
TCP port range: 30000 to 32767 |
All IP addresses: 0.0.0.0/0 |
Default access port range of the NodePort Service in the cluster. |
Yes |
These ports must permit requests from VPC, container, and ELB CIDR blocks. |
UDP port range: 30000 to 32767 |
All |
Container CIDR block |
Used for mutual access between nodes and containers. |
No |
N/A |
All |
Security group of worker nodes |
Used for mutual access between worker nodes. |
No |
N/A |
TCP port 22 |
Port that allows remote access to Linux ECSs using SSH. |
Recommended |
N/A |
Outbound rule |
All |
Allow traffic on all ports by default. You are advised to retain this setting. |
Yes |
If you want to harden security by allowing traffic only on specific ports, remember to allow such ports. For details, see Hardening Outbound Rules. |
A security group named {Cluster name}-cce-control-{Random ID} is automatically created for the master node. For details about the default ports, see Table 2.
Direction |
Port |
Description |
Modifiable |
Inbound rules |
TCP port 5444 |
VPC CIDR block |
Allow access from kube-apiserver, which provides lifecycle management for Kubernetes resources. |
No |
N/A |
TCP port 5444 |
TCP port 9443 |
VPC CIDR block |
Allow the network add-on of a worker node to access the master node. |
No |
N/A |
TCP port 5443 |
Allow kube-apiserver of the master node to listen to the worker nodes. |
Recommended |
The port must allow traffic from the CIDR blocks of the VPC, container, and the control plane of the hosted service mesh. |
TCP port 8445 |
VPC CIDR block |
Allow the storage add-on of a worker node to access the master node. |
No |
N/A |
All |
IP addresses of this security group |
Allow traffic from all IP addresses of this security group. |
No |
N/A |
Outbound rule |
All |
Allow traffic on all ports by default. |
No |
N/A |
A security group named {Cluster name}-cce-node-{Random ID} is automatically created for each worker node. For details about the default ports, see Table 3.
Direction |
Port |
Description |
Modifiable |
Inbound rules |
UDP port 4789 |
Allow access between containers. |
No |
N/A |
TCP port 10250 |
CIDR block of the master node |
Allow the master node to access kubelet on a worker node, for example, by running kubectl exec {pod}. |
No |
N/A |
Yes |
TCP port 22 |
Recommended |
N/A |
All |
No |
N/A |
Outbound rule |
All |
Yes |
A security group named {Cluster name}-cce-control-{Random ID} is automatically created for the master node. For details about the default ports, see Table 4.
Direction |
Port |
Description |
Modifiable |
Inbound rules |
UDP port 4789 |
No |
N/A |
TCP port 5444 |
VPC CIDR block |
No |
N/A |
TCP port 5444 |
TCP port 9443 |
VPC CIDR block |
No |
N/A |
TCP port 5443 |
Recommended |
TCP port 8445 |
VPC CIDR block |
No |
N/A |
All |
No |
N/A |
Outbound rule |
All |
No |
N/A |
A security group named {Cluster name}-cce-node-{Random ID} is automatically created for each worker node. For details about the default ports, see Table 5.
Direction |
Port |
Description |
Modifiable |
Inbound rules |
TCP port 10250 |
No |
N/A |
Yes |
TCP port 22 |
Recommended |
N/A |
All |
No |
N/A |
All |
Container subnet CIDR block |
Allow traffic from all source IP addresses in the container subnet CIDR block. |
No |
N/A |
Outbound rule |
All |
Yes |
A security group named {Cluster name}-cce-control-{Random ID} is automatically created for the master node. For details about the default ports, see Table 6.
Direction |
Port |
Description |
Modifiable |
Inbound rules |
TCP port 5444 |
No |
N/A |
TCP port 5444 |
VPC CIDR block |
No |
N/A |
TCP port 9443 |
VPC CIDR block |
No |
N/A |
TCP port 5443 |
Recommended |
TCP port 8445 |
VPC CIDR block |
No |
N/A |
All |
No |
N/A |
All |
No |
N/A |
Outbound rule |
All |
No |
N/A |
Security group of an ENI
In a CCE Turbo cluster, an additional security group named {Cluster name }-cce-eni-{Random ID} is created. By default, containers in the cluster are bound to this security group. For details about the default ports, see Table 7.
Direction |
Port |
Description |
Modifiable |
Inbound rules |
All |
No |
N/A |
VPC CIDR block |
Allow traffic from all IP addresses of the VPC CIDR block. |
No |
N/A |
Outbound rule |
All |
No |
N/A |
By default, all security groups created by CCE allow all the outbound traffic. You are advised to retain this configuration. To harden outbound rules, ensure that the ports listed in the following table are enabled.
Port |
Allowed CIDR |
Description |
UDP port 53 |
DNS server of the subnet |
Allow traffic on the port for domain name resolution. |
UDP: 4789 (required only for clusters using the container tunnel network model) |
All IP addresses |
TCP port 5443 |
TCP port 5444 |
CIDR blocks of the VPC and container |
TCP port 6443 |
None |
TCP port 8445 |
VPC CIDR block |
TCP port 9443 |
VPC CIDR block |
