Help Center>
Cloud Container Engine>
User Guide (ME-Abu Dhabi Region)>
FAQs>
Cluster>
Cluster Creation>
Why Cannot I Create a CCE Cluster?
Updated on 2024-01-04 GMT+08:00
Overview
This section describes how to locate and rectify the fault if you fail to create a CCE cluster.
Details
Possible causes:
- The Network Time Protocol daemon (ntpd) is not installed or fails to be installed, Kubernetes components fail to pass the pre-verification, or the disk partition is incorrect. The current solution is to create a cluster again. For details about how to locate the fault, see Locating the Failure Cause.
View the cluster logs to identify the cause and rectify the fault.
- Log in to the CCE console. In the navigation pane, click Operation Records above the cluster list to view operation records.
- Click the record of the Failed status to view error information.
Figure 1 Viewing the operation details
- Rectify the fault based on the error information and create a cluster again.
Parent topic: Cluster Creation
