Help Center>
Cloud Container Engine>
User Guide (ME-Abu Dhabi Region)>
FAQs>
API & kubectl FAQs>
How Can I Access a CCE Cluster?
Updated on 2024-01-04 GMT+08:00
You can use either of the following methods to access the cluster API Server:
- (Recommended) Through the cluster API. This access mode uses certificate authentication. It is suitable for API calls on scale thanks to its direct connection to the API Server. This is a recommended option.
- API Gateway. This access mode uses token authentication. You need to obtain a toke using your account. This access mode applies to small-scale API calls. API gateway flow control may be triggered when APIs are called on scale.
Parent topic: API & kubectl FAQs
