Help Center/ Cloud Container Engine/ User Guide (ME-Abu Dhabi Region)/ FAQs/ Networking/ Network Fault/ What Should I Do If a Node Fails to Connect to the Internet (Public Network)?
Updated on 2024-01-04 GMT+08:00
If a node fails to be connected to the Internet, perform the following operations:
Check Item 1: Whether an EIP Has Been Bound to the Node
Log in to the ECS console and check whether an EIP has been bound to the ECS corresponding to the node.
If there is an IP address in the EIP column, an EIP has been bound. If there is no IP address in that column, bind one.
Check Item 2: Whether a Network ACL Has Been Configured for the Node
Log in to the VPC console. In the navigation pane, choose Access Control > Network ACLs. Check whether a network ACL has been configured for the subnet where the node is located and whether external access is restricted.
