Help Center> Cloud Container Engine> User Guide (ME-Abu Dhabi Region)> FAQs> Workload> Container Configuration> What Is the Retry Mechanism When CCE Fails to Start a Pod?
Updated on 2022-11-10 GMT+08:00
CCE is a fully managed Kubernetes service and is fully compatible with Kubernetes APIs and kubectl.
In Kubernetes, the spec of a pod contains a restartPolicy field. The value of restartPolicy can be Always, OnFailure, or Never. The default value is Always.
  • Always: When a container fails, kubelet automatically restarts the container.
  • OnFailure: When a container stops running and the exit code is not 0 (indicating normal exit), kubelet automatically restarts the container.
  • Never: kubelet does not restart the container regardless of the container running status.
restartPolicy applies to all containers in a pod.
restartPolicy only refers to restarts of the containers by kubelet on the same node. When containers in a pod exit, kubelet restarts them with an exponential back-off delay (10s, 20s, 40s, …), which is capped at five minutes. Once a container has been running for 10 minutes without any problems, kubelet resets the restart backoff timer for the container.
The settings of restartPolicy vary depending on the controller:
  • Replication Controller (RC) and DaemonSet: restartPolicy must be set to Always to ensure continuous running of the containers.
  • Job: restartPolicy must be set to OnFailure or Never to ensure that containers are not restarted after being executed.
