Accessing an IP Address Outside of a Cluster That Uses a VPC Network by Using Source Pod IP Addresses Within the Cluster
In a CCE cluster that uses a VPC network, when pods try to communicate with external systems, CCE automatically translates the source IP addresses of the pods into the IP addresses of the nodes that are running them. This allows pods to communicate with external systems using the node IP addresses. This process is known as pod IP address masquerading or Source Network Address Translation (SNAT).
You are allowed to configure private CIDR blocks for your clusters using the nonMasqueradeCIDRs parameter. If a pod tries to access a private CIDR block, the source node will not perform NAT on the pod IP address. Instead, the VPC route table can directly send the pod data packet to the destination, which means, the pod IP address is directly used to communicate with the private CIDR block in the cluster.
You have a cluster that uses the VPC network and whose version is v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later.
Default Non-Masqueraded CIDR Block Settings in a CCE Cluster
By default, CCE uses the following well-known private CIDR blocks as non-masqueraded CIDR blocks in each cluster:
- 10.0.0.0/8
- 172.16.0.0/12
- 192.168.0.0/16
Additionally, in a CCE cluster that uses a secondary VPC CIDR block, adding or resetting a node will automatically include the secondary CIDR block in the non-masqueraded CIDR blocks.
This means that when a pod communicates with external resources and accesses these CIDR blocks, the source IP address of the data packet remains unchanged and is not translated into the node IP address.
Scenarios Where the Default Non-Masqueraded CIDR Blocks Do Not Fit
The default non-masqueraded CIDR block settings in CCE clusters apply to typical scenarios, but in certain specific scenarios, these default settings may not be sufficient to meet user requirements. The following shows typical examples:
- Cross-node access to pods in a cluster
When a node in a Kubernetes cluster needs to access a pod on another node, the response data packet sent from the pod is automatically subject to SNAT. This changes the source IP address from the pod IP address to the IP address of the node that runs the pod. However, this automatic IP address translation can sometimes lead to communication issues, making cross-node access impossible.
To enable a node to access pods on other nodes, you can add the CIDR block of the subnet where the node is located to the nonMasqueradeCIDRs parameter. This will skip SNAT and allow the original IP addresses of pods on these nodes to be retained.
- Access from other resources in the same VPC as a cluster to pods in the cluster
In certain scenarios, it may be necessary to access the original IP addresses of pods on different nodes in a CCE cluster directly from other resources (such as ECSs) in the same VPC as the cluster. However, with SNAT enabled by default, the source IP addresses of the data packets are replaced with the IP addresses of the nodes that run these pods when the data packets pass through the nodes. This makes it difficult for these resources to access pods directly.
To enable direct access from resources in the same VPC as the cluster to pods, you can add the CIDR blocks of the subnets where these resources are located to the nonMasqueradeCIDRs parameter. This will skip SNAT and ensure that the source IP addresses of the data packets remain the same as the original IP addresses of pods.
Precautions
If a security group or ACL is configured for a cloud service and only the IP address of the node where the pod runs is allowed to access the service, SNAT is required to translate the pod IP address into the node IP address for successful access. As a result, the CIDR block of the subnet where the server is located cannot be added to the nonMasqueradeCIDRs configuration.
The default setting of pod IP address masquerading (SNAT) is usually sufficient. However, if you need to retain the original IP addresses of pods in specific scenarios, you can configure the nonMasqueradeCIDRs parameter.
Before doing so, make sure you have evaluated your application scenario and understood the potential risks of improper configuration, because it may block access within clusters. If you are unsure whether to configure this parameter, it is recommended that you keep the default settings and adjust the configuration later once the requirement is clarified.
To reserve the source IP address of a pod when the pod accesses a CIDR block, you can configure nonMasqueradeCIDRs to specify the CIDR block that does not need to be masqueraded.
- In the navigation pane, choose Settings and click the Network tab.
- Modify the range of the CIDR blocks for non-masquerading access to preserve the source pod IP address when accessing a specified CIDR block. Make sure the parameter configuration complies with the following rules:
- Each CIDR block must comply with the CIDR format and must be a valid IPv4 CIDR block.
Example of a correct CIDR block: 192.168.1.0/24
Example of an incorrect CIDR block: 192.168.1.1/24 (incompliant with the CIDR format)
- The CIDR blocks you configured do not overlap with each other.
Example of correct CIDR blocks: 192.168.1.0/24 and 192.168.2.0/24
Example of incorrect CIDR blocks: 192.168.1.0/24 and 192.168.1.128/25 (The two CIDR blocks overlap.)
- The nonMasqueradeCIDRs parameter must contain all destination CIDR blocks that you want them to use the original pod IP addresses for communications.
- After the modification, click Confirm configuration. The setting takes effect within 1 minute.
