Advanced Configuration of Nginx Ingress Controller
Parameter Optimization in High-Concurrency Scenarios
In high-concurrency scenarios, you can configure parameters for optimization in either of the following ways:
- Use ConfigMap to optimize the overall parameters of Nginx Ingress Controller.
- Use InitContainers to optimize the kernel parameters of Nginx Ingress Controller.
The optimized value.yaml configuration file is as follows:
controller: image: repository: registry.k8s.io/ingress-nginx/controller registry: "" image: "" tag: "v1.5.1" # Controller version digest: "" ingressClassResource: name: ccedemo # The name of each Ingress Controller in the same cluster must be unique and cannot be nginx or cce. controllerValue: "k8s.io/ingress-nginx-demo" # The listening identifier of each Ingress Controller in the same cluster must be unique and cannot be set to k8s.io/ingress-nginx. ingressClass: ccedemo # The name of each Ingress Controller in the same cluster must be unique and cannot be nginx or cce. service: annotations: kubernetes.io/elb.id: 5083f225-9bf8-48fa-9c8b-67bd9693c4c0 #ELB ID kubernetes.io/elb.class: performance # This annotation is required only for dedicated load balancers. # Nginx parameter optimization config: keep-alive-requests: 10000 upstream-keepalive-connections: 200 max-worker-connections: 65536 # Kernel parameter optimization extraInitContainers: - name: init-myservice image: busybox securityContext: privileged: true command: ['sh', '-c', 'sysctl -w net.core.somaxconn=65535;sysctl -w net.ipv4.ip_local_port_range="1024 65535"'] extraVolumeMounts: # Mount the /etc/localtime file on the node to synchronize the time zone. - name: localtime mountPath: /etc/localtime readOnly: true extraVolumes: - name: localtime type: Hostpath hostPath: path: /etc/localtime admissionWebhooks: # Disable webhook authentication. enabled: false patch: enabled: false resources: # Set the controller's resource limit, which can be customized. requests: cpu: 200m memory: 200Mi defaultBackend: # Set defaultBackend. enabled: true image: repository: registry.k8s.io/defaultbackend-amd64 registry: "" image: "" tag: "1.5" digest: ""
admissionWebhook Configuration
Nginx Ingress Controller supports admissionWebhook configuration. You can configure the controller.admissionWebhook parameter to verify the validity of ingress objects. This prevents ingress-controller from continuously reloading resources due to incorrect configuration, which may cause service interruption.
![](https://support.huaweicloud.com/intl/en-us/ae-ad-1-usermanual-cce/public_sys-resources/note_3.0-en-us.png)
- When the admissionWebhook feature is used, webhook-related configurations must be enabled on the API server, including MutatingAdmissionWebhook and ValidatingAdmissionWebhook.
The feature switch is --admission-control=MutatingAdmissionWebhook,ValidatingAdmissionWebhook.
If it is not enabled, submit a service ticket to enable it.
- After admissionWebhook is enabled, if you need to uninstall and reinstall Nginx Ingress Controller, residual secrets exist and need to be manually cleared.
The value.yaml configuration file for enabling admissionWebhook is as follows:
controller: image: repository: registry.k8s.io/ingress-nginx/controller registry: "" image: "" tag: "v1.5.1" # Controller version digest: "" ingressClassResource: name: ccedemo # The name of each Ingress Controller in the same cluster must be unique and cannot be nginx or cce. controllerValue: "k8s.io/ingress-nginx-demo" # The listening identifier of each Ingress Controller in the same cluster must be unique and cannot be set to k8s.io/ingress-nginx. ingressClass: ccedemo # The name of each Ingress Controller in the same cluster must be unique and cannot be nginx or cce. service: annotations: kubernetes.io/elb.id: 5083f225-9bf8-48fa-9c8b-67bd9693c4c0 #ELB ID kubernetes.io/elb.class: performance # This annotation is required only for dedicated load balancers. config: keep-alive-requests: 100 extraVolumeMounts: # Mount the /etc/localtime file on the node to synchronize the time zone. - name: localtime mountPath: /etc/localtime readOnly: true extraVolumes: - name: localtime type: Hostpath hostPath: path: /etc/localtime admissionWebhooks: annotations: {} enabled: true extraEnvs: [] failurePolicy: Fail port: 8443 certificate: "/usr/local/certificates/cert" key: "/usr/local/certificates/key" namespaceSelector: {} objectSelector: {} labels: {} existingPsp: "" networkPolicyEnabled: false service: annotations: {} externalIPs: [] loadBalancerSourceRanges: [] servicePort: 443 type: ClusterIP createSecretJob: resources: #Annotation{} limits: cpu: 20m memory: 40Mi requests: cpu: 10m memory: 20Mi patchWebhookJob: resources: {} patch: enabled: true image: registry: registry.k8s.io #registry.k8s.io is the image repository of the webhook official website. Replace it with the address of the repository where the image is located. image: ingress-nginx/kube-webhook-certgen # webhook image tag: v1.1.1 digest: "" pullPolicy: IfNotPresent priorityClassName: "" podAnnotations: {} nodeSelector: kubernetes.io/os: linux tolerations: [] labels: {} securityContext: runAsNonRoot: true runAsUser: 2000 fsGroup: 2000 resources: # Set the controller's resource limit, which can be customized. requests: cpu: 200m memory: 200Mi defaultBackend: # Set defaultBackend. enabled: true image: repository: registry.k8s.io/defaultbackend-amd64 registry: "" image: "" tag: "1.5" digest: ""
Check whether admissionWebhook is verified when incorrect annotations are configured for the ingress.
For example, configure the following incorrect annotations for the ingress:
... annotations: nginx.ingress.kubernetes.io/auth-tls-pass-certificate-to-upstream: "false" nginx.ingress.kubernetes.io/auth-tls-verify-client: optional nginx.ingress.kubernetes.io/auth-tls-verify-depth: "1" ...
When the ingress service is created, the following interception information is displayed:
