Mounting Object Storage Across Accounts
Application Scenarios
- Cross-account data sharing. For example, multiple teams within a company need to share data, but each team uses a different account.
- Cross-account data migration and backup. When account A is about to be disabled, all data stored in the account needs to be transferred to a new account (account B).
- Data processing and analysis. For example, account B is an external data processor and needs to access raw data from account A to perform tasks such as big data analysis and machine learning.
By linking object storage across accounts, you can share data, lower storage and transmission expenses, and guarantee data security and consistency. This enables various teams or organizations to securely and conveniently access each other's data resources, eliminating the need for repeated storage and redundant transmission. Additionally, data is kept current and compliant, enhancing overall service efficiency and security.
Assume that account B needs to access and use an OBS bucket of account A. For details, see Figure 1 and Table 1.
Procedure |
Description |
Configure an OBS bucket policy and ACL using account A and grant account B required permissions like the read and write permissions. |
Create a PV and a PVC based on the OBS bucket of account A using account B and mount the PVC to the required workload. |
Check whether the pod created by account B has the required permissions based on the bucket policy. |
Once you have studied this example, delete any associated resources to prevent incurring settlement fees. |
- The involved accounts are in the same region.
- You have created a cluster where the CCE Container Storage (Everest) add-on is installed. The add version must be 1.1.11 or later, and the cluster version must be 1.15 or later.
- An ECS with an EIP bound has been created in the same VPC as the cluster, and the ECS has been connected to the cluster through kubectl.
Step 1: Create an OBS Bucket Policy and ACL
- Configure the parameters. In this example, only some mandatory parameters are described. You can keep the default values for other parameters.
Table 2 Bucket policy parameters Parameter
Example
Policy Name
Enter a name.
example01
Effect
Specify the behavior of a policy.
- Allow: The actions defined in the policy are allowed.
- Deny: The actions defined in the policy are denied.
Allow
Principal
Specify authorized accounts. (Multiple accounts can be selected.) For different types of authorized accounts, the OBS console provides different templates for authorizations.
- All accounts: Any account can execute the current bucket policy without identity authentication, which may pose data security risks.
- Current account: Grant permissions to a specific IAM account under the current account.
- Other accounts: Grant permissions to a specific IAM account under another account.
Other accounts
XXX(account ID)/XXX (IAM ID)
Resources
Specify the authorized resources.
- Entire bucket (including the objects in it): Allow authorized accounts to perform certain actions on a bucket and the objects in it.
- Current bucket: Allow authorized accounts to perform certain actions on the current bucket.
- Specific objects: Allow authorized accounts to perform certain actions on the specified objects in a bucket.
Actions
Specify actions.
- Use a template: Use a permission template preset on the OBS console. If you selected Bucket Read/Write, the Specified actions option will be selected by default in the Advanced Settings area.
- Customize: Customize the actions.
Use a template > Bucket Read/Write
- In the navigation pane, choose Permissions > Bucket ACL. In the right pane, click Add under User Access. Enter the account ID of the authorized user, select Read and Write for Access to Bucket, select Read for Access to Objects, select Read and Write for Access to ACL, and click OK.
Step 2: Create a Workload with an OBS Volume Mounted
- Create a ConfigMap named paas-obs-endpoint and configure the region and endpoint of OBS.
vim config.yamlThe content is as follows: (For details about the parameters, see Table 3.)
apiVersion: v1 kind: ConfigMap metadata: name: paas-obs-endpoint # The value must be paas-obs-endpoint. namespace: kube-system # The value must be kube-system. data: obs-endpoint: | {"<region_name>": "<endpoint_address>"}Create the ConfigMap using config.yaml.
kubectl create -f config.yamlTable 3 ConfigMap parameters ConfigMap
metadata.name
ConfigMap name, which is fixed at paas-obs-endpoint and cannot be changed
metadata.namespace
Namespace, which is fixed at kube-system and cannot be changed
data.obs-endpoint
Region names and endpoints are in key-value pairs. Replace <region_name> and <endpoint_address> with specific values. If multiple values are needed, use commas (,) to separate them.
For details about its value, see Regions and Endpoints.
- Create a secret named test-user. (This secret is used to provide access credentials when volumes are mounted to CSI, and its name can be customized.)
- Obtain the AK. Go back to the management console, hover the cursor over the username in the upper right corner and choose My Credentials from the drop-down list.
In the navigation pane, choose Access Keys. On the page displayed, click Create Access Key.
Click OK and download the AK.
- Encode the AK using Base64 and save the encoded AK and SK. If the AK obtained is xxx and the SK is yyy, run the following commands:
echo -n xxx|base64 echo -n yyy|base64
- Create a secret YAML file, for example, test_user.yaml.
vim test_user.yamlThe content is as follows: (For details about the parameters, see Table 4.)
apiVersion: v1 data: access.key: QUxPQUlJU****** secret.key: aVMwZkduQ****** kind: Secret metadata: name: test-user namespace: default type: cfe/secure-opaqueCreate a secret using test_user.yaml.
kubectl create -f test_user.yamlTable 4 Secret parameters Parameter
Example
access.key
A Base64-encoded AK
QUxPQUlJU******
secret.key
A Base64-encoded SK
aVMwZkduQ******
type
Key type, which is fixed at cfe/secure-opaque and cannot be changed
When this type is used, the data entered by users will be automatically encrypted.
cfe/secure-opaque
- Create a PV named testing_abc and mount the secret named test_user to the PV.
vim testing_abc.yamlThe content is as follows: (For details about the parameters, see Table 5.)
kind: PersistentVolume apiVersion: v1 metadata: name: testing-abc annotations: pv.kubernetes.io/bound-by-controller: 'yes' pv.kubernetes.io/provisioned-by: everest-csi-provisioner spec: capacity: storage: 1Gi mountOptions: - default_acl=bucket-owner-full-control #New OBS mounting parameters csi: driver: obs.csi.everest.io volumeHandle: obs-cce-test # Name of the OBS bucket to be mounted fsType: s3fs # obsfs indicates a parallel file system, and s3fs indicates an OBS bucket. volumeAttributes: everest.io/obs-volume-type: STANDARD # Bucket type, which can be STANDARD or WARM when an OBS bucket is used everest.io/region: <region_name> # Region where the OBS bucket is located (Replace it with the actual value.) storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner nodePublishSecretRef: # AK/SK used for mounting the OBS bucket name: test-user namespace: default accessModes: - ReadWriteMany persistentVolumeReclaimPolicy: Retain # PV reclaim policy storageClassName: csi-obs # csi-obs specifies an OBS storage class that is automatically created. You can customize it as required. volumeMode: Filesystem
Create the PV using testing_abc.yaml.
kubectl create -f testing_abc.yamlTable 5 PV parameters Parameter
Example
mountOptions.default_acl
Specify access control policies for a bucket and objects in the bucket. In this example, account A owns the bucket, and both account A and account B have the ability to upload data.
- private: The bucket or objects can only be fully accessed by the owner of the bucket.
- public-read: The owner of the bucket has complete control over both the bucket and its objects. While other users can read data from the bucket, they are unable to modify, delete, or upload any data within it.
- public-read-write: The owner of the bucket has complete control over the bucket and its objects. Other users can read and write data from and to the bucket.
- bucket-owner-read: Users who have uploaded objects to the bucket has complete control over the objects, while the bucket owner is only granted read permissions for said objects. This mode is usually used in cross-account sharing scenarios.
- bucket-owner-full-control: Users who have uploaded objects to the bucket are granted write permissions for those specific objects, but not read permissions by default. The bucket owner has complete control over all objects within the bucket. This mode is usually used in cross-account sharing scenarios.
NOTE:Due to the bucket policy that was configured using account A, account B has been granted read and write permissions for the entire bucket, including objects uploaded by both account A and B.
csi.nodePublishSecretRef
Specify the secret to be mounted.
- name: name of a secret
- namespace: namespace where the secret is in
test-user
default
csi.volumeHandle
Specify the name of the OBS bucket to be mounted.
obs-cce-test (OBS bucket name authorized by account A)
csi.fsType
Specify the file type.
- obsfs: Create an OBS parallel file system.
- s3fs: Create an OBS bucket.
s3fs
NOTICE:The file type specified by the PV and the PVC must match in order for the PV to be bound to the corresponding PVC. If they do not match, the binding cannot occur.
accessModes
Specify the access mode of the storage volume. OBS supports only ReadWriteMany.
- ReadWriteOnce: A storage volume can be mounted to a single node in read-write mode.
- ReadWriteMany: A storage volume can be mounted to multiple nodes in read-write mode.
ReadWriteMany
Specify the reclaim policy for the PV.
- Delete: When a PVC is deleted, both the PV and underlying storage resources will be deleted. If the everest.io/reclaim-policy: retain-volume-only annotation is added to the YAML file, the underlying storage resources will be retained.
- Retain: When a PVC is deleted, both the PV and underlying storage resources will be retained. You need to manually delete them. After the PVC is deleted, the PV is in the Released state and cannot be bound to a PVC again.
Retain
NOTE:If multiple PVs use the same OBS volume, use Retain to prevent the underlying volume from being deleted with one of the PV.
- Create a PVC named pvc-test-abc and bind the new PV testing_abc to it.
vim pvc_test_abc.yamlThe file content is as follows:apiVersion: v1 kind: PersistentVolumeClaim metadata: name: pvc-test-abc namespace: default annotations: csi.storage.k8s.io/node-publish-secret-name: test-user # Mount a secret. csi.storage.k8s.io/node-publish-secret-namespace: default # Namespace of the secret everest.io/obs-volume-type: STANDARD # Bucket type, which can be STANDARD or WARM when an OBS bucket is used csi.storage.k8s.io/fstype: s3fs # File type. obsfs indicates a parallel file system, and s3fs indicates an OBS bucket. volume.beta.kubernetes.io/storage-provisioner: everest-csi-provisioner spec: accessModes: - ReadWriteMany # The value must be ReadWriteMany for object storage. resources: requests: storage: 1Gi # Storage capacity of a PVC. This parameter is valid only for verification (fixed to 1, cannot be empty or 0). The value setting does not take effect for OBS buckets. storageClassName: csi-obs # csi-obs specifies an OBS storage class that is automatically created. You can customize it as required. volumeName: testing-abc # PV name
Create the PVC using pvc_test_abc.yaml.
kubectl create -f pvc_test_abc.yaml - Create a workload and mount the PVC to it. The following uses an Nginx Deployment as an example.
vim obs_deployment_example.yamlThe file content is as follows:
apiVersion: apps/v1 kind: Deployment metadata: name: obs-deployment-example # Workload name, which can be customized namespace: default spec: replicas: 1 selector: matchLabels: app: obs-deployment-example # Label, which can be customized template: metadata: labels: app: obs-deployment-example spec: containers: - image: nginx name: container-0 volumeMounts: - mountPath: /tmp # PVC mount path, which can be customized as required name: pvc-obs-example restartPolicy: Always imagePullSecrets: - name: default-secret volumes: - name: pvc-obs-example persistentVolumeClaim: claimName: pvc-test-abc # PVC name
Create the workload named obs-deployment-example using obs_deployment_example.yaml.
kubectl create -f obs_deployment_example.yamlCheck whether the workload has been created.
kubectl get pod
If information similar to the following is displayed and the workload is in the Running state, the workload has been created.
NAME READY STATUS RESTARTS AGE obs-deployment-example-6b4dfd7b57-frfxv 1/1 Running 0 22h
Step 3: Check the Pod Actions on the OBS Bucket
- Check whether the pod can read and write objects in the OBS bucket created by account A and assume that a test.txt file is present in the OBS bucket.
Run the following command to access the created workload. (You can press Ctrl+D to exit the current workload.)
kubectl -n default exec -it obs-deployment-example-6b4dfd7b57-frfxv -c container-0 -- bashRun the following command to check the pod actions on test.txt. /tmp specifies the PVC mount path.
ls -l /tmp/test.txtIf information similar to the following is displayed, the pod has the read and write permissions on the test.txt file, which is related to the bucket policy set by account A.
-rwxrwxrwx 1 root root 4 Sep 5 09:09 /tmp/test.txt
- Check whether the pod can read and write data from and to the objects uploaded by itself in the OBS bucket.
Create a test01.txt file in /tmp and write test\n into the file.
echo -e "test\n" > /tmp/test01.txt
Run the following command to check the test01.txt content and check whether the pod can read and write new objects uploaded by itself: (Account A can check the new objects in the OBS bucket.)
cat /tmp/test01.txtIf information similar the following is displayed, the pod has the read and write permissions on the objects uploaded by itself.
test
Step 4: Clear Resources
Once you have studied this example, delete any associated resources to prevent incurring settlement fees. If you plan to learn other examples, wait until they are finished before doing any clean-up.
- Run the following command to delete the workload:
kubectl delete -f obs_deployment_example.yamlInformation similar to the following is displayed:
deployment.apps "obs-deployment-example" deleted
- Run the following command to delete the PVC:
kubectl delete -f pvc_test_abc.yamlInformation similar to the following is displayed:
persistentvolumeclaim "pvc-test-abc" deleted
- Run the following command to delete the PV:
kubectl delete -f testing_abc.yamlInformation similar to the following is displayed:
persistentvolume "testing-abc" deleted
- Run the following command to delete the secret:
kubectl delete -f test_user.yamlInformation similar to the following is displayed:
secret "test-user" deleted
- Run the following command to delete the ConfigMap:
kubectl delete -f config.yamlInformation similar to the following is displayed:
configmap "paas-obs-endpoint" deleted
Common Issues
If a workload fails to be created, locate the fault based on the error information in the pod events. For details, see Table 6.
Error |
Possible Cause |
Fault Locating |
0/4 nodes are available: pod has unbound immediate PersistentVolumeClaims. preemption: 0/4 nodes are available: 4 Preemption is not helpful for scheduling. |
The PVC is not bound to any PV. |
MountVolume.SetUp failed for volume "obs-cce-example": rpc error: code = Unknown desc = failed to get secret(paas.longaksk), err: get secret(paas.longaksk) failed: get secret paas.longaksk from namespace kube-system failed: secrets "paas.longaksk" not found |
The required secret cannot be found when the storage volume is mounted to the workload. |
MountVolume.SetUp failed for volume "pv-obs-example": rpc error: code = Internal desc = [8032c354-4e1b-41b0-81ce-9d4b3f8c49c9] get obsUrl failed before mount bucket obs-cce-example, get configMap paas-obs-endpoint from namespace kube-system failed: configmaps "paas-obs-endpoint" not found |
The ConfigMap that stores the OBS endpoint is not present or is incorrectly configured. |
