El contenido no se encuentra disponible en el idioma seleccionado. Estamos trabajando continuamente para agregar más idiomas. Gracias por su apoyo.
Binding a Security Group to a Pod Using an Annotation
Application Scenarios
In Cloud Native 2.0 network mode, pods use ENIs or sub-ENIs of the VPC. You can configure a security group for a pod using a pod's annotation.
Configure a security group in either of the following cases:
  • To newly bind a security group to a pod, use annotation yangtse.io/security-group-ids.
  • To bind more security groups to a pod, use annotation yangtse.io/additional-security-group-ids.
The priority of the security group bound to a pod using annotation yangtse.io/security-group-ids is higher than those of the security groups in the security group policy (SecurityGroup) and cluster container network configuration (NetworkAttachmentDefinition).
A CCE Turbo cluster is available and the cluster version meets the following requirements:
  • v1.23: v1.23.16-r0 or later
  • v1.25: v1.25.11-r0 or later
  • v1.27: v1.27.8-r0 or later
  • v1.28: v1.28.6-r0 or later
  • v1.29: v1.29.2-r0 or later
  • Versions later than v1.29
Using kubectl
  • Create a workload with a security group configured. The security group bound to the pod is subject to the one configured using an annotation.
    If the pod has been bound to a security group, the configuration will be overwritten.
    apiVersion: apps/v1
    kind: Deployment
      replicas: 3
      selector:
        matchLabels:
          app: nginx
      template:
          labels:
            app: nginx
          annotations:
            yangtse.io/security-group-ids: *****  # Security group ID. Use commas (,) to separate multiple security groups.
          containers:
            - name: container-0
              image: nginx:alpine
              resources:
                limits:
                  cpu: 100m
                  memory: 200Mi
                requests:
                  cpu: 100m
                  memory: 200Mi
          imagePullSecrets:
            - name: default-secret
  • Add an additional security group for the workload.
    apiVersion: apps/v1
    kind: Deployment
      replicas: 3
      selector:
        matchLabels:
          app: nginx
      template:
          labels:
            app: nginx
          annotations:
            yangtse.io/additional-security-group-ids: *****  # Security group ID. Use commas (,) to separate multiple security groups.
          containers:
            - name: container-0
              image: nginx:alpine
              resources:
                limits:
                  cpu: 100m
                  memory: 200Mi
                requests:
                  cpu: 100m
                  memory: 200Mi
          imagePullSecrets:
Table 1 Annotations for configuring a security group for a pod
Annotation
Value Range
Configure a security group for a pod. The security group of the pod is subject to the one configured using this annotation. If the pod already has a security group, the original security group will be overwritten.
Security group IDs. A maximum of five IDs are allowed. Use commas (,) to separate multiple security groups.
Add more security groups to a pod.
Security group IDs. The total number of newly added security group IDs and existing security group IDs cannot exceed 5. Use commas (,) to separate multiple security groups.
Utilizamos cookies para mejorar nuestro sitio y tu experiencia. Al continuar navegando en nuestro sitio, tú aceptas nuestra política de cookies. Descubre más
