Updated on 2024-01-04 GMT+08:00
Scheduling Workloads
Volcano is a Kubernetes-based batch processing platform with high-performance general computing capabilities like task scheduling engine, heterogeneous chip management, and task running management. It provides end users with computing frameworks from multiple domains such as AI, big data, gene, and rendering. It also offers job scheduling, job management, and queue management for computing applications.
Kubernetes typically uses its default scheduler to schedule workloads. To use Volcano, specify Volcano for your workloads. For details about the Kubernetes scheduler, see Specify schedulers for pods.
When a large number of workloads are scheduled, Volcano prints a large number of logs. In this case, you can use Volcano with LTS. Otherwise, the disk space of the node where Volcano resides may be used up. For details, see Collecting Data Plane Logs.
Using Volcano
When using Volcano to schedule workloads, you only need to configure schedulerName in the spec field of the pod and set the parameter to volcano. The following is an example:
apiVersion: apps/v1
kind: Deployment
  labels:
    app: nginx
  replicas: 4
  selector:
    matchLabels:
      app: nginx
  template:
      annotations:
        # Submit the job to the q1 queue.
        scheduling.volcano.sh/queue-name: "q1"
        volcano.sh/preemptable: "true"
      labels:
        app: nginx
      # Specify Volcano as the scheduler.
      schedulerName: volcano
      containers:
      - name: nginx
        image: nginx
        imagePullPolicy: IfNotPresent
        resources:
          limits:
            cpu: 1
            memory: 100Mi
          requests:
            cpu: 1
            memory: 100Mi
        ports:
        - containerPort: 80
Additionally, Volcano supports the workload queues and preemption, which can be implemented through pod annotations. The following table lists the supported annotations.
Table 1 Pod annotations supported by Volcano
Pod Annotations
Remarks
scheduling.volcano.sh/queue-name: "<queue-name>"
Specifies the queue to which the workload belongs. <queue-name> indicates the queue name.
Indicates whether a job can be preempted. If this function is enabled, the job can be preempted.
Options:
  • true: Preemption is enabled. This option is enabled by default.
  • false: Preemption is disabled.
You can obtain pod details to check whether the pod is scheduled by Volcano and the allocated queue.
kubectl describe pod <pod_name>
Command output:
Spec:
  Min Member:  1
  Min Resources:
    Cpu:     100m
    Memory:  100Mi
  Queue:     q1
Status:
  Conditions:
    Last Transition Time:  2023-05-30T01:54:43Z
    Reason:                tasks in gang are ready to be scheduled
    Status:                True
    Transition ID:         70be1d7d-3532-41e0-8324-c7644026b38f
    Type:                  Scheduled
  Phase:                   Running
Events:
  Type    Reason     Age              From     Message
  Normal  Scheduled  0s (x3 over 2s)  volcano  pod group is ready
