Updated on 2024-01-04 GMT+08:00
Node Label and Taint Check
Check Items
  • Check whether custom node labels are lost.
  • Check whether there are any unexpected taints newly added on the node, which will affect workload scheduling.
  2. In the navigation pane, choose Nodes. On the displayed page, click the Nodes tab, select all nodes, and click Labels and Taints to view the labels and taints of the current node.
Solution
Custom labels will not be changed during a cluster upgrade. If you find that labels are lost or added unexpectedly, contact technical support.
If you find a new taint (node.kubernetes.io/upgrade) on a node, the node may be skipped during the upgrade. For details, see Node Skipping Check.
If you find that other taints are added to the node, contact technical support.
