Updated on 2024-01-04 GMT+08:00
Node and Container Network Check
Check Items
  • Check whether nodes are running properly.
  • Check whether the node network is functional.
  • Check whether the container network is functional.
If the container network malfunctions, services will be abnormal. Check whether your services are running properly.
If a node component or the node network malfunctions, the node will be abnormal. Perform the following steps to check the node status:
  2. In the navigation pane, choose Nodes. On the displayed page, click the Nodes tab and check whether there are abnormal nodes (which can be filtered in the Status column).
Solution
If the node status is abnormal, contact technical support.
If the container network is abnormal and your services are affected, contact technical support and confirm the abnormal network access path.
Source
Destination
Destination Type
Possible Fault
  • Pods (inside a cluster)
  • Nodes (inside a cluster)
  • Cloud servers outside the cluster but in the same VPC as the cluster
  • Outside the VPC to which the cluster belongs
Public IP address of Service ELB
Cluster traffic load balancing entry
Private IP address of Service ELB
Public IP address of ingress ELB
Private IP address of ingress ELB
Public IP address of NodePort Service
Cluster traffic entry
The kube proxy configuration is overwritten. This fault has been rectified in the upgrade process.
Private IP address of NodePort Service
ClusterIP Service
Service network plane
Non NodePort Service port
Container network
Cross-node pods
Container network plane
Pods on the same node
Service and pod domain names are resolved by CoreDNS.
Domain name resolution
External domain names are resolved based on the CoreDNS hosts configuration.
After CoreDNS is upgraded, the configuration is overwritten. This fault has been rectified in the add-on upgrade process.
External domain names are resolved based on the CoreDNS upstream server.
External domain names are not resolved by CoreDNS.
