Help Center>
Cloud Container Engine>
User Guide (ME-Abu Dhabi Region)>
Clusters>
Upgrading a Cluster>
Performing Post-Upgrade Verification>
Pod Check
Updated on 2024-01-04 GMT+08:00
Pod Check
Check Items
- Check whether there are unexpected pods in the cluster.
- Check whether there are any pods that ran properly originally in the cluster restart unexpectedly.
- In the navigation pane, choose Workloads. On the displayed page, select all namespaces, click the Pods tab, and check whether there are abnormal pods.
- Check the Restarts column for the pods that are restarted unexpectedly.
Solution
If there are abnormal pods in your cluster after the cluster upgrade, contact technical support.
Parent topic: Performing Post-Upgrade Verification
