Help Center>
Cloud Container Engine>
User Guide (ME-Abu Dhabi Region)>
Clusters>
Upgrading a Cluster>
Troubleshooting for Pre-upgrade Check Exceptions>
Node Swap
Updated on 2024-01-04 GMT+08:00
Node Swap
Check Items
Check whether swap has been enabled on cluster nodes.
Solution
By default, swap is disabled on CCE nodes. Check the necessity of enabling swap manually and determine the impact of disabling this function. Run the swapoff -a command to disable swap.
Parent topic: Troubleshooting for Pre-upgrade Check Exceptions
