Updated on 2024-01-04 GMT+08:00
Nodes' System Parameter Settings
Check Items
Check whether the default system parameter settings on your nodes are modified.
Solution
If the MTU value of the bond0 network on your BMS node is not the default value 1500, this check item failed.
Non-default parameter settings may lead to service packet loss. Change them back to the default values.
