Updated on 2024-01-04 GMT+08:00
Historical Upgrade Records
Check Items
Check whether the source version of the cluster is earlier than v1.11 and the target version is later than v1.23.
Solution
If the source version of the cluster is earlier than v1.11, it is risky to upgrade the cluster to a version later than v1.23. In this case, contact technical support.
