Updated on 2024-01-04 GMT+08:00
Key Commands of Nodes
Check Items
Whether some key commands that the node upgrade depends on are working
Solution
  • Scenario 1: The package manager command fails to be executed.
    The rpm or dpkg command fails to be executed. Log in to the node and check whether the following commands are available:
    • rpm:
      rpm -qa
    • dpkg:
      dpkg -l
  • Scenario 2: The systemctl status command fails to be executed.
    If the systemctl status command on a node is unavailable, many check items will be affected. Log in to the node and check the availability of the following commands:
    systemctl status kubelet
