Updated on 2024-01-04 GMT+08:00
Enhanced CPU Policies
Check Items
Check whether the current cluster version and the target version support enhanced CPU policy.
Solution
Scenario: Only the current cluster version supports the enhanced CPU policy function. The target version does not support the enhanced CPU policy function.
Upgrade to a cluster version that supports the enhanced CPU policy function. The following table lists the cluster versions that support the enhanced CPU policy function.
Table 1 List of cluster versions that support the enhanced CPU policy function
Cluster Version
Enhanced CPU Policy
Clusters of v1.17 or earlier
Not supported
Clusters of v1.19
Not supported
Clusters of v1.21
Not supported
Clusters of v1.23 or later
Supported
