Updated on 2024-01-04 GMT+08:00
Everest Restrictions
Check Items
Check whether there are any compatibility restrictions on the current Everest add-on.
Table 1 List of Everest add-on versions with compatibility restrictions
Add-on Name
Versions Involved
everest
v1.0.2-v1.0.7
v1.1.1-v1.1.5
Solution
There are compatibility restrictions on the current Everest add-on and it cannot be upgraded with the cluster upgrade. Contact technical support.
