Updated on 2024-01-04 GMT+08:00
Container Engine
Introduction to Container Engines
Container engines, one of the most important components of Kubernetes, manage the lifecycle of images and containers. The kubelet interacts with a container runtime through the Container Runtime Interface (CRI).
CCE supports containerd and Docker. containerd is recommended for its shorter traces, fewer components, higher stability, and less consumption of node resources.
Table 1 Comparison between container engines
Item
containerd
Docker
Tracing
kubelet --> CRI plugin (in the containerd process) --> containerd
  • Docker (Kubernetes v1.23 and earlier):
    kubelet --> dockershim (in the kubelet process) --> docker --> containerd
  • Docker (community solution for Kubernetes v1.24 or later):
    kubelet --> cri-dockerd (kubelet uses CRI to connect to cri-dockerd) --> docker--> containerd
Command
crictl
docker
Kubernetes CRI
Native support
Support through dockershim or cri-dockerd
Pod delayed startup
Minor
High
kubelet CPU/memory usage
Minor
High
Runtime's CPU/memory usage
Minor
High
Common Commands of containerd and Docker
containerd does not support Docker APIs and Docker CLI, but you can run crictl commands to implement similar functions.
Table 2 Image-related commands
No.
Docker Command
containerd Command
Remarks
docker images [Option] [Image name[:Tag]]
crictl images [Option] [Image name[:Tag]]
List local images.
2
docker pull [Option] Image name[:Tag|@DIGEST]
crictl pull [Option] Image name[:Tag|@DIGEST]
Pull images.
3
docker push
None
Pushing images.
4
docker rmi [Option] Image...
crictl rmi [Option] Image ID...
Delete a local image.
5
docker inspect Image ID
crictl inspecti Image ID
Check images.
Table 3 Container-related commands
No.
Docker Command
containerd Command
Remarks
docker ps [Option]
crictl ps [Option]
List containers.
2
docker create [Option]
crictl create [Option]
Create a container.
3
docker start [Option] Container ID...
crictl start [Option] Container ID...
Start a container.
4
docker stop [Option] Container ID...
crictl stop [Option] Container ID...
Stop a container.
5
docker rm [Option] Container ID...
crictl rm [Option] Container ID...
Delete a container.
6
docker attach [Option] Container ID
crictl attach [Option] Container ID
Connect to a container.
7
docker exec [Option] Container ID Startup command [Parameter...]
crictl exec [Option] Container ID Startup command [Parameter...]
Access the container.
8
docker inspect [Option] Container name|ID...
crictl inspect [Option] Container ID...
Query container details.
9
docker logs [Option] Container ID
crictl logs [Option] Container ID
View container logs.
10
docker stats [Option] Container ID...
crictl stats [Option] Container ID
Check the resource usage of the container.
11
docker update [Option] Container ID...
crictl update [Option] Container ID...
Update container resource limits.
Table 4 Pod-related commands
No.
Docker Command
containerd Command
Remarks
None
crictl pods [Option]
List pods.
2
None
crictl inspectp [Option] Pod ID...
View pod details.
3
None
crictl start [Option] Pod ID...
Start a pod.
4
None
crictl runp [Option] Pod ID...
Run a pod.
5
None
crictl stopp [Option] Pod ID...
Stop a pod.
6
None
crictl rmp [Option] Pod ID...
Delete a pod.
Containers created and started by containerd are immediately deleted by kubelet. containerd does not support suspending, resuming, restarting, renaming, and waiting for containers, nor Docker image build, import, export, comparison, push, search, and labeling. containerd does not support file copy. You can log in to the image repository by modifying the configuration file of containerd.
Differences in Tracing
  • Docker (Kubernetes 1.23 and earlier versions):
    kubelet --> docker shim (in the kubelet process) --> docker --> containerd
  • containerd:
    kubelet --> cri plugin (in the containerd process) --> containerd
Although Docker has added functions such as swarm cluster, docker build, and Docker APIs, it also introduces bugs. Compared with containerd, Docker has one more layer of calling. Therefore, containerd is more resource-saving and secure.
Container Engine Version Description
  • Docker
    • EulerOS/CentOS: docker-engine 18.9.0, a Docker version customized for CCE. Security vulnerabilities will be fixed in a timely manner.
  • containerd: 1.6.14
