Help Center>
Cloud Container Engine>
User Guide (ME-Abu Dhabi Region)>
Clusters>
Upgrading a Cluster>
Troubleshooting for Pre-upgrade Check Exceptions>
containerd.sock
Updated on 2024-01-04 GMT+08:00
containerd.sock
Check Items
Check whether the containerd.sock file exists on the node. This file affects the startup of container runtime in the Euler OS.
Solution
Scenario: The Docker used by the node is the customized Euler-docker.
- Log in to the node.
- Run the rpm -qa | grep docker | grep euleros command. If the command output is not empty, the Docker used on the node is Euler-docker.
- Run the ls /run/containerd/containerd.sock command. If the file exists, Docker startup will fail.
- Run the rm -rf /run/containerd/containerd.sock command and perform the cluster upgrade check again.
Parent topic: Troubleshooting for Pre-upgrade Check Exceptions
