Help Center>
Cloud Container Engine>
User Guide (ME-Abu Dhabi Region)>
Clusters>
Upgrading a Cluster>
Troubleshooting for Pre-upgrade Check Exceptions>
ASM Version
Updated on 2024-01-04 GMT+08:00
ASM Version
Check Items
Check the following items:
- Check whether ASM is used by the cluster.
- Check whether the current ASM version supports the target cluster version.
Solution
- Upgrade ASM and then upgrade the cluster. The adaptation rules between ASM and cluster versions are as follows:
Table 1 Adaptation rules between ASM and cluster versions ASM Version
Cluster Version
1.3
v1.13, v1.15, v1.17, or v1.19
1.6
v1.15, v1.17, v1.19, or v1.21
1.8
1.13
v1.21 or v1.23
1.15
v1.21, v1.23, or v1.25
- If ASM is not required, delete it before the upgrade. After the upgrade, the cluster cannot be bound to ASM that does not match the table. For example, if you want to upgrade a cluster of v1.21 and ASM of v1.8 to v1.23, upgrade the ASM first.
Parent topic: Troubleshooting for Pre-upgrade Check Exceptions
