Help Center>
Cloud Container Engine>
User Guide (ME-Abu Dhabi Region)>
Clusters>
Upgrading a Cluster>
Troubleshooting for Pre-upgrade Check Exceptions>
Node Python Commands
Updated on 2024-01-04 GMT+08:00
Check Items
Check whether the Python commands are available on a node.
Check Method
/usr/bin/python --version echo $?
If the command output is not 0, the check fails.
Solution
Install Python before the upgrade.
Parent topic: Troubleshooting for Pre-upgrade Check Exceptions
