Help Center>
Cloud Container Engine>
User Guide (ME-Abu Dhabi Region)>
Clusters>
Upgrading a Cluster>
Troubleshooting for Pre-upgrade Check Exceptions>
Node CPUs
Updated on 2024-01-04 GMT+08:00
Node CPUs
Check Items
Check whether the number of CPUs on the master node is greater than 2.
Solution
If the number of CPUs on the master node is 2, contact technical support to expand the number to 4 or more.
Parent topic: Troubleshooting for Pre-upgrade Check Exceptions
