Updated on 2024-01-04 GMT+08:00
Node OS
Check Items
Check whether the OS kernel version of the node is supported by CCE.
Solution
CCE nodes run depending on the initial standard kernel version when they are created. CCE has performed comprehensive compatibility tests based on this kernel version. A non-standard kernel version may cause unexpected compatibility issues during a node upgrade and the upgrade may fail. For details, see High-Risk Operations and Solutions.
This type of nodes should not be upgraded. Reset the node to the standard kernel version before the upgrade by following the instructions in Resetting a Node.
