Help Center>
Cloud Container Engine>
User Guide (ME-Abu Dhabi Region)>
Clusters>
Upgrading a Cluster>
Troubleshooting for Pre-upgrade Check Exceptions>
CRDs
Updated on 2024-01-04 GMT+08:00
CRDs
Check Items
Check the following items:
- Check whether the key CRD packageversions.version.cce.io of the cluster is deleted.
- Check whether the cluster key CRD network-attachment-definitions.k8s.cni.cncf.io is deleted.
Solution
If check results are abnormal, contact technical support.
Parent topic: Troubleshooting for Pre-upgrade Check Exceptions
