Monitoring Custom Metrics Using Prometheus
You can use AOM ICAgent to obtain custom metric data of workloads as described in Monitoring Custom Metrics on AOM. You can also install the prometheus add-on in a cluster and use Prometheus as the monitoring platform.
The following procedure uses an Nginx application as an example to describe how to use Prometheus to monitor custom metrics:
- Installing the Add-on
CCE provides an add-on that integrates prometheus functions. You can install it with several clicks.
- Accessing Prometheus
(Optional) Bind a LoadBalancer Service to prometheus so that prometheus can be accessed from external networks.
- Preparing an Application
Prepare an application image. The application must provide a metric monitoring API for ICAgent to collect data, and the monitoring data must comply with the prometheus specifications.
- Monitoring Custom Metrics
Use the application image to deploy a workload in a cluster. Custom metrics will be automatically reported to Prometheus.
- Configuring Collection Rules for Custom Metrics
After collection rules are configured, custom metrics are reported to the metric-server, which can be used in scenarios like workload auto scaling.
- Accessing Grafana
View prometheus monitoring data on Grafana, a visualization panel.
To use prometheus to monitor custom metrics, the application needs to provide a metric monitoring API. For details, see Prometheus Monitoring Data Collection.
Prometheus periodically calls the metric monitoring API (/metrics by default) of an application to obtain monitoring data. The application needs to provide the metric monitoring API for Prometheus to call, and the monitoring data must meet the following specifications of Prometheus:
# TYPE nginx_connections_active gauge nginx_connections_active 2 # TYPE nginx_connections_reading gauge nginx_connections_reading 0
Prometheus provides clients in various languages. For details about the clients, see Prometheus CLIENT LIBRARIES. For details about how to develop an exporter, see WRITING EXPORTERS. The Prometheus community provides various third-party exporters that can be directly used. For details, see EXPORTERS AND INTEGRATIONS.
Install the add-on based on the cluster version and actual requirements.
- prometheus (EOM): supports only clusters of v1.21 or earlier.
After the add-on is installed, you can deploy workloads and Services. The StatefulSet named prometheus refers to Prometheus Server.
You can create a public network LoadBalancer Service so that Prometheus can be accessed from an external network.
- Log in to the CCE console, and click the name of the cluster with the prometheus add-on installed to access the cluster console. On the displayed page, choose Networking from the navigation pane.
- Click Create from YAML in the upper right corner to create a public network LoadBalancer Service.
apiVersion: v1 kind: Service metadata: name: prom-lb #Service name, which can be customized. namespace: monitoring labels: app: prometheus component: server annotations: kubernetes.io/elb.id: 038ff*** #Replace it with the ID of the public network load balancer in the VPC that the cluster belongs to. spec: ports: - name: cce-service-0 protocol: TCP port: 88 #Service port, which can be customized. targetPort: 9090 #Default port of Prometheus. Retain the default value. selector: app: prometheus component: server release: cceaddon-prometheus type: LoadBalancer - After the creation, visit load balancer public IP:Service port to access Prometheus.
- Choose Status > Targets to view the targets monitored by prometheus.
A self-developed application must provide a metric monitoring API for ICAgent to collect data, and the monitoring data must comply with the Prometheus specifications. For details, see Prometheus Monitoring Data Collection.
This document uses Nginx as an example to describe how to collect monitoring data. There is a module named ngx_http_stub_status_module in Nginx, which provides basic monitoring functions. You can configure the nginx.conf file to provide an interface for external systems to access Nginx monitoring data.
- Log in to a Linux VM that can access to the Internet and run Docker commands.
- Create an nginx.conf file. Add the server configuration under http to enable Nginx to provide an interface for the external systems to access the monitoring data.
user nginx; worker_processes auto; error_log /var/log/nginx/error.log warn; pid /var/run/nginx.pid; events { worker_connections 1024; } http { include /etc/nginx/mime.types; default_type application/octet-stream; log_format main '$remote_addr - $remote_user [$time_local] "$request" ' '$status $body_bytes_sent "$http_referer" ' '"$http_user_agent" "$http_x_forwarded_for"'; access_log /var/log/nginx/access.log main; sendfile on; #tcp_nopush on; keepalive_timeout 65; #gzip on; include /etc/nginx/conf.d/*.conf; server { listen 8080; server_name localhost; location /stub_status { stub_status on; access_log off; } } } - Use this configuration to create an image and a Dockerfile file.
vi Dockerfile
The content of Dockerfile is as follows:FROM nginx:1.21.5-alpine ADD nginx.conf /etc/nginx/nginx.conf EXPOSE 80 CMD ["nginx", "-g", "daemon off;"]
- Use this Dockerfile to build an image and upload it to SWR. The image name is nginx:exporter.
- In the navigation pane, choose My Images. Click Upload Through Client in the upper right corner. On the page displayed, click Generate a temporary login command and click
to copy the command. - Run the login command copied in the previous step on the node. If the login is successful, the message "Login Succeeded" is displayed.
- Run the following command to build an image named nginx. The image version is exporter.
docker build -t nginx:exporter .
- Tag the image and upload it to the image repository. Change the image repository address and organization name based on your requirements.
docker tag nginx:exporter {swr-address}/{group}/nginx:exporter docker push {swr-address}/{group}/nginx:exporter
- View application metrics.
- Use nginx:exporter to create a workload.
- Access the container and use http://<ip_address>:8080/stub_status to obtain nginx monitoring data. <ip_address> indicates the IP address of the container. Information similar to the following is displayed.
# curl http://127.0.0.1:8080/stub_status Active connections: 3 server accepts handled requests 146269 146269 212 Reading: 0 Writing: 1 Waiting: 2
The data format of the monitoring data provided by nginx:exporter does not meet the requirements of Prometheus. Convert the data format to the format required by Prometheus. To convert the format of Nginx metrics, use nginx-prometheus-exporter. Deploy nginx:exporter and nginx-prometheus-exporter in the same pod and add the following annotations during deployment. Then Prometheus can automatically collect metrics.
kind: Deployment
apiVersion: apps/v1
namespace: default
replicas: 1
selector:
matchLabels:
app: nginx-exporter
template:
labels:
app: nginx-exporter
annotations:
prometheus.io/scrape: "true"
prometheus.io/port: "9113"
prometheus.io/path: "/metrics"
prometheus.io/scheme: "http"
containers:
- name: container-0
image: 'nginx:exporter' # Replace it with the address of the image you uploaded to SWR.
resources:
limits:
cpu: 250m
memory: 512Mi
requests:
cpu: 250m
memory: 512Mi
- name: container-1
image: 'nginx/nginx-prometheus-exporter:0.9.0'
command:
- nginx-prometheus-exporter
args:
- '-nginx.scrape-uri=http://127.0.0.1:8080/stub_status'
imagePullSecrets:
- name: default-secret
In the preceding description:
- prometheus.io/scrape indicates whether to enable Prometheus to collect pod monitoring data. The value is true.
- prometheus.io/port indicates the port for collecting monitoring data.
- prometheus.io/path indicates the URL of the API for collecting monitoring data. If this parameter is not set, the default value /metrics is used.
- prometheus.io/scheme: protocol used for data collection. The value can be http or https.
After the application is deployed, a pod with a collection path of port 9113 can be found under Status > Targets.
On the Graph tab, enter nginx. The related metrics are displayed.
For details about how to configure collection rules, see Metrics Discovery and Presentation Configuration. If you have upgraded the add-on, original configurations are inherited and used.
- Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose ConfigMaps and Secrets.
- Switch to the monitoring namespace, find the user-adapter-config ConfigMap (adapter-config in earlier versions) on the ConfigMaps tab, and click Update.
- In the window that slides out from the right, click Edit in the operation column of Data for the config.yaml file. Then add a custom metric collection rule under the rules field. Click OK.
You can add multiple collection rules by adding multiple configurations under the rules field. For details, see Metrics Discovery and Presentation Configuration.
The following is an example of customizing a collection rule for the nginx:export:rules: - seriesQuery: '{__name__=~"^nginx_.*",container!="POD",namespace!="",pod!=""}' resources: overrides: namespace: resource: namespace pod: resource: pod name: matches: (.*) metricsQuery: 'sum(<<.Series>>{<<.LabelMatchers>>,container!="POD"}) by (<<.GroupBy>>)'
The preceding example applies only to the nginx:export application in this example. If you need to collect custom metrics, add or change rules according to the official guide.
- Redeploy the custom-metrics-apiserver in the monitoring namespace.
- After custom-metrics-apiserver runs successfully, you can select the custom metrics reported by the nginx:export application when creating an HPA policy. For details, see HPA Policy.
Accessing Grafana
The prometheus add-on has Grafana (an open-source visualization tool) installed and interconnected with Prometheus. You can create a public network LoadBalancer Service so that you can access Grafana from the public network and view Prometheus monitoring data on Grafana.
Click the access address to access Grafana and select a proper dashboard to view the aggregated content.
- Click Create from YAML in the upper right corner to create a public network LoadBalancer Service for Grafana.
apiVersion: v1 kind: Service metadata: name: grafana-lb #Service name, which can be customized. namespace: monitoring labels: app: grafana annotations: kubernetes.io/elb.id: 038ff*** #Replace it with the ID of the public network load balancer in the VPC that the cluster belongs to. spec: ports: - name: cce-service-0 protocol: TCP port: 80 #Service port, which can be customized. targetPort: 3000 #Default port of Grafana. Retain the default value. selector: app: grafana type: LoadBalancer - After the creation, visit load balancer public IP:Service port to access Grafana and select a proper dashboard to view the aggregated data.
Appendix: Grafana data persistence
If Grafana data is not persistent, the data may be lost when Grafana container is restarted. You can mount cloud storage to the Grafana container to achieve Grafana data persistence.
- Use kubectl to connect to the cluster where Grafana is located..
- Create the PVC of an EVS disk.
apiVersion: v1 kind: PersistentVolumeClaim metadata: name: grafana-pvc namespace: monitoring annotations: everest.io/disk-volume-type: SSD labels: failure-domain.beta.kubernetes.io/region: ae-ad-1 failure-domain.beta.kubernetes.io/zone: spec: accessModes: - ReadWriteOnce resources: requests: storage: 10Gi storageClassName: csi-disk
The EVS disk and the node where Grafana resides must be in the same AZ. Otherwise, the EVS disk cannot be attached.
- failure-domain.beta.kubernetes.io/region: region where the EVS disk resides.
- failure-domain.beta.kubernetes.io/zone: AZ where the EVS disk resides.
- storage: EVS disk size. Set this parameter as required.
You can also create EVS disks on the CCE console. For details, see Automatically Creating an EVS Disk.
- Modify the Grafana workload configuration and mount the EVS disk.
kubectl edit deploy grafana -n monitoring
Add the EVS disk to the container in the YAML file, as shown in the following figure. The PVC name must be the same as that in 2, and the mount path must be /var/lib/grafana.
In addition, the upgrade policy must be modified for the Grafana workload. The maximum number of pods is 1.
... template: spec: volumes: - name: cce-pvc-grafana persistentVolumeClaim: claimName: grafana-pvc ... containers: - volumeMounts: - name: cce-pvc-grafana mountPath: /var/lib/grafana ... strategy: type: RollingUpdate rollingUpdate: maxUnavailable: 1 maxSurge: 1Save the configuration. The Grafana workload will be upgraded and the EVS disk will be mounted.
