Updated on 2024-01-04 GMT+08:00
NPU Scheduling
You can use NPUs in CCE containers.
Using NPUs
Create a workload and request NPUs. You can specify the number of NPUs as follows:
kind: Deployment
apiVersion: apps/v1
  namespace: default
  replicas: 1
  selector:
    matchLabels:
      app: npu-test
  template:
      labels:
        app: npu-test
      containers:
        - name: container-0
          image: nginx:perl
          resources:
            limits:
              cpu: 250m
              huawei.com/ascend-310: '1'
              memory: 512Mi
            requests:
              cpu: 250m
              memory: 512Mi
      imagePullSecrets:
      - name: default-secret
Specify the number of NPUs to be requested in huawei.com/ascend-310.
When you use huawei.com/ascend-310 to specify the number of NPUs, the values of requests and limits must be the same.
After huawei.com/ascend-310 is specified, workloads will be scheduled only to nodes with NPUs. If NPUs are insufficient, a Kubernetes event similar to "0/2 nodes are available: 2 Insufficient huawei.com/ascend-310." will be reported.
To use NPUs on the CCE console, select the NPU quota and specify the number of NPUs to be used when creating a workload.
NPU Node Labels
CCE will label NPU-enabled nodes that are ready to use.
$ kubectl get node -L accelerator/huawei-npu
NAME           STATUS   ROLES    AGE     VERSION                                    HUAWEI-NPU
10.100.2.59    Ready    <none>   2m18s   v1.19.10-r0-CCE21.11.1.B006-21.11.1.B006   ascend-310
When using NPUs, you can enable the affinity between pods and nodes based on labels so that the pods can be scheduled to the correct nodes.
kind: Deployment
apiVersion: apps/v1
  namespace: default
  replicas: 1
  selector:
    matchLabels:
      app: npu-test
  template:
      labels:
        app: npu-test
      nodeSelector:
        accelerator/huawei-npu: ascend-310
      containers:
        - name: container-0
          image: nginx:perl
          resources:
            limits:
              cpu: 250m
              memory: 512Mi
            requests:
              cpu: 250m
              memory: 512Mi
      imagePullSecrets:
