Updated on 2024-01-04 GMT+08:00
CCE AI Suite (Ascend NPU)
Introduction
Ascend NPU is a device management add-on that supports Huawei NPUs in containers.
After this add-on is installed, you can create Ascend-accelerated nodes to quickly and efficiently process inference and image recognition.
  • To use Ascend-accelerated nodes in a cluster, the Ascend NPU add-on must be installed.
  • After an AI-accelerated node is migrated, the node will be reset. Manually reinstall the NPU driver.
Installing the Add-on
  1. Log in to the CCE console and click the cluster name to access the cluster console. Choose Add-ons in the navigation pane, locate CCE AI Suite (Ascend NPU) on the right, and click Install.
  2. Set NPU parameters. The add-on uses the following parameters by default. The default NPU settings provided by the add-on can satisfy most scenarios and require no changes.
    	"check_frequency_failed_threshold": 100,
    	"check_frequency_fall_times": 3,
    	"check_frequency_gate": false,
    	"check_frequency_recover_threshold": 100,
    	"check_frequency_rise_times": 2,
    	"container_path": "/usr/local/HiAI_unused",
    	"host_path": "/usr/local/HiAI_unused"
  3. Click Install.
Components
Table 1 huawei-npu components
Component
Resource Type
npu-driver-installer
Used for installing an NPU driver on NPU nodes.
DaemonSet
