Hibernating or Waking Up a Cluster
If a pay-per-use cluster is not needed temporarily, hibernate it to reduce costs.
After a cluster is hibernated, resources such as workloads cannot be created or managed in the cluster.
Precautions
  • During cluster wakeup, the master node may fail to start due to insufficient resources, which leads to a cluster wakeup failure. In this case, wait for a while and try again.
  • After a cluster is woken up, it takes 3 to 5 minutes to initialize data. Deliver services after the cluster runs properly.
Hibernating a Cluster
  1. Log in to the CCE console. In the navigation pane, choose Clusters.
  2. Locate the cluster to be hibernated, click ... to view more operations on the cluster, and choose Hibernate.
  3. In the dialog box displayed, check the precautions and click Yes. Wait until the cluster is hibernated.
Waking Up a Cluster
  2. Click Wake Up in the row of the target cluster.
  3. When the cluster status changes from Waking up to Running, the cluster is woken up. It takes about 3 to 5 minutes to wake up the cluster.
