Updated on 2024-01-04 GMT+08:00
Cluster Configuration Management
CCE allows you to manage cluster parameters, through which you can let core components work under your very requirements.
This function is supported only in clusters of v1.15 and later. It is not displayed for versions earlier than v1.15.
  1. Log in to the CCE console. In the navigation pane, choose Clusters.
  2. Locate the target cluster, click ... to view more operations on the cluster, and choose Manage.
  3. On the Manage Components page on the right, change the values of the Kubernetes parameters listed in the following table.
    Table 1 kube-apiserver configuration
    Item
    Value
    Tolerance time of pods for an unavailable node
    default-not-ready-toleration-seconds
    Specifies the default tolerance time. The configuration takes effect for all pods by default. You can configure different tolerance time for pods. In this case, the tolerance time configured for the pod is used. For details, see Taints and Tolerations.
    If the specified tolerance time is too short, pods may be frequently migrated in scenarios like a network jitter. If the specified tolerance time is too long, services may be interrupted during this period after the node is faulty.
    Default: 300s
    Tolerance time of pods for an inaccessible node
    default-unreachable-toleration-seconds
    Default: 300s
    Maximum number of concurrent modification API requests
    max-mutating-requests-inflight
    Maximum number of concurrent mutating requests. When the value of this parameter is exceeded, the server rejects requests.
    The value 0 indicates that there is no limitation on the maximum number of concurrent modification requests. This parameter is related to the cluster scale. You are advised not to change the value.
    Manual configuration is no longer supported since cluster v1.21. The value is automatically specified based on the cluster scale.
    • 200 for clusters with 50 or 200 nodes
    • 500 for clusters with 1000 nodes
    • 1000 for clusters with 2000 nodes
    Maximum number of concurrent non-modification API requests
    max-requests-inflight
    Maximum number of concurrent non-mutating requests. When the value of this parameter is exceeded, the server rejects requests.
    The value 0 indicates that there is no limitation on the maximum number of concurrent non-modification requests. This parameter is related to the cluster scale. You are advised not to change the value.
    • 400 for clusters with 50 or 200 nodes
    • 1000 for clusters with 1000 nodes
    • 2000 for clusters with 2000 nodes
    Ports used by NodePort services
    service-node-port-range
    NodePort port range. After changing the value, go to the security group page and change the TCP/UDP port range of node security groups 30000 to 32767. Otherwise, ports other than the default port cannot be accessed externally.
    If the port number is smaller than 20106, a conflict may occur between the port and the CCE health check port, which may further lead to unavailable cluster. If the port number is greater than 32767, a conflict may occur between the port and the ports in net.ipv4.ip_local_port_range, which may further affect the network performance.
    Default:
    From 30000 to 32767
    Value range:
    Min > 20105
    Max < 32768
    Request timeout
    request-timeout
    Default request timeout interval of kube-apiserver. Exercise caution when changing the value of this parameter. Ensure that the changed value is proper to prevent frequent API timeout or other errors.
    This parameter is supported only by clusters of v1.19.16-r30, v1.21.10-r10, v1.23.8-r10, v1.25.3-r10, and later versions.
    Default:
    1m0s
    Value range:
    Min ≥ 1s
    Max ≤ 1 hour
    Overload control
    support-overload
    Cluster overload control. If enabled, concurrent requests are dynamically controlled based on the resource pressure of master nodes to keep them and the cluster available.
    This parameter is supported only by clusters of v1.23 or later.
    • false: Overload control is disabled.
    • true: Overload control is enabled.
    Table 2 Scheduler configurations
    Item
    Value
    Query per second (QPS) for the scheduler to access kube-apiserver
    kube-api-qps
    QPS for communicating with kube-apiserver.
    • If the number of nodes in a cluster is less than 1000, the default value is 100.
    • If a cluster contains 1000 or more nodes, the default value is 200.
    Burst for the scheduler to access kube-apiserver
    kube-api-burst
    Burst to use while talking with kube-apiserver.
    GPU sharing
    enable-gpu-share
    Whether to enable GPU sharing. This parameter is supported only by clusters of v1.23.7-r10, v1.25.3-r0, and later.
    • When disabled, ensure that pods in the cluster do not use the shared GPU (that is, the annotation of cce.io/gpu-decision does not exist in pods).
    • When enabled, ensure that the annotation of cce.io/gpu-decision exists in pods that use GPU resources in the cluster.
    Default value: true
    Table 3 kube-controller-manager configurations
    Item
    Value
    Deployment
    concurrent-deployment-syncs
    Number of deployment objects that are allowed to sync concurrently
    Default: 5
    Endpoint
    concurrent-endpoint-syncs
    Number of endpoint syncing operations that will be done concurrently
    Default: 5
    Garbage collector
    concurrent-gc-syncs
    Number of garbage collector workers that are allowed to sync concurrently
    Default: 20
    Job
    concurrent-job-syncs
    Number of job objects that are allowed to sync concurrently
    Default: 5
    Namespace
    concurrent-namespace-syncs
    Number of namespace objects that are allowed to sync concurrently
    Default: 10
    ReplicaSet
    concurrent-replicaset-syncs
    Number of replica sets that are allowed to sync concurrently
    Default: 5
    RsourceQuota
    concurrent-resource-quota-syncs
    Number of resource quotas that are allowed to sync concurrently
    Default: 5
    Servicepace
    concurrent-service-syncs
    Number of services that are allowed to sync concurrently
    Default: 10
    ServiceAccountToken
    concurrent-serviceaccount-token-syncs
    Number of service account token objects that are allowed to sync concurrently
    Default: 5
    TTLAfterFinished
    concurrent-ttl-after-finished-syncs
    Number of ttl-after-finished-controller workers that are allowed to sync concurrently
    Default: 5
    RC
    concurrent-rc-syncs
    Number of replication controllers that are allowed to sync concurrently
    This parameter is used only in clusters of v1.21 to v1.23. In clusters of v1.25 and later, this parameter is deprecated (officially deprecated from v1.25.3-r0 on).
    Default: 5
    Period for syncing the number of pods in horizontal pod autoscaler
    horizontal-pod-autoscaler-sync-period
    How often HPA audits metrics in a cluster.
    Default: 15 seconds
    QPS for the controller to access kube-apiserver
    kube-api-qps
    QPS to use while talking with kube-apiserver
    Burst for the controller to communicate with kube-apiserver
    kube-api-burst
    Threshold for triggering garbage collection of terminated pods
    terminated-pod-gc-threshold
    Number of terminated pods that can exist in a cluster. If there are more terminated pods than the expected number in the cluster, the terminated pods that exceed the number will be deleted.
    Default: 1000
    Value range: 10 to 12500
    HPA
    concurrent-horizontal-pod-autoscaler-syncs
    Number of HPA auto scaling requests that can be concurrently processed. This parameter is available only in clusters of v1.27 or later.
    Default: 5
    Value range: 1 to 50
    Table 4 Network component configurations (supported only by CCE Turbo clusters)
    Item
    Value
    Minimum number of ENIs bound to a node at the cluster level
    nic-minimum-target
    Minimum number of container ENIs bound to a node
    The parameter value must be a positive integer. The value 10 indicates that there are at least 10 container ENIs bound to a node. If the number you entered exceeds the container ENI quota of the node, the ENI quota will be used.
    Default: 10
    Maximum number of ENIs pre-bound to a node at the cluster level
    nic-maximum-target
    If the number of ENIs bound to a node exceeds the value of nic-maximum-target, the system does not proactively pre-bind ENIs.
    Checking the upper limit of pre-bound container ENIs is enabled only when the value of this parameter is at least equal to the minimum number of container ENIs (nic-minimum-target) bound to a node.
    The parameter value must be a positive integer. The value 0 indicates that the check on the upper limit of pre-bound container ENIs is disabled. If the number you entered exceeds the container ENI quota of the node, the ENI quota will be used.
    Default: 0
    Number of ENIs pre-bound to a node at the cluster level
    nic-warm-target
    Extra ENIs will be pre-bound after the nic-minimum-target is used up in a pod. The value can only be a number.
    When the value of nic-warm-target + the number of bound ENIs is greater than the value of nic-maximum-target, the system will pre-bind ENIs based on the difference between the value of nic-maximum-target and the number of bound ENIs.
    Default: 2
    Reclaim number of ENIs pre-bound to a node at the cluster level
    nic-max-above-warm-target
    Only when the number of idle ENIs on a node minus the value of nic-warm-target is greater than the threshold, the pre-bound ENIs will be unbound and reclaimed. Only numbers are allowed.
    • A large value will accelerate pod startup but slow down the unbinding of idle container ENIs and decrease the IP address usage.
    • A small value will speed up the unbinding of idle container ENIs and increase the IP address usage but will slow down pod startup, especially when a large number of pods increase instantaneously.
    Default: 2
    Low threshold of the number of container ENIs bound to a node in a cluster
    prebound-subeni-percentage
    High threshold of the number of bound ENIs
    This parameter is being discarded. Use the dynamic pre-binding parameters of the other four ENIs.
    Default: 0:0
    Table 5 Extended controller configurations (supported only by clusters of v1.21 and later)
    Item
    Value
    Resource quota management
    enable-resource-quota
    Indicates whether to automatically create a ResourceQuota when creating a namespace. With quota management, you can control the number of workloads of each type and the upper limits of resources in a namespace or related dimensions.
    • false: no auto creation
    • true: auto creation enabled. For details about the resource quota defaults, see Configuring Resource Quotas.
      In high-concurrency scenarios (for example, creating pods in batches), the resource quota management may cause some requests to fail due to conflicts. Do not enable this function unless necessary. To enable this function, ensure that there is a retry mechanism in the request client.
    Default: false
  4. Click OK.
