Help Center>
Cloud Container Engine>
User Guide (ME-Abu Dhabi Region)>
Network>
Service>
LoadBalancer>
Enabling ICMP Security Group Rules
Updated on 2024-01-04 GMT+08:00
If a workload uses UDP for both load balancing and health check, enable ICMP security group rules for the backend servers.
- Log in to the ECS console, find the ECS corresponding to any node where the workload runs, and click the ECS name. On the displayed ECS details page, record the security group name.
- Log in to the VPC console. In the navigation pane on the left, choose Access Control > Security Groups. In the security group list on the right, click the security group name obtained in step 1.
- On the page displayed, click the Inbound Rules tab and click Add Rule to add an inbound rule for ECS. Then, click OK.
- You only need to add security group rules to any node where the workload runs.
- The security group must have rules to allow access from the CIDR block 100.125.0.0/16.
Parent topic: LoadBalancer
