Updated on 2024-01-04 GMT+08:00
Managing Workload Scaling Policies
After an HPA or CustomedHPA policy is created, you can update, clone, edit, and delete the policy, as well as edit the YAML file.
Checking an HPA Policy
You can view the rules, status, and events of an HPA policy and handle exceptions based on the error information displayed.
  2. In the navigation pane, choose Policies. On the page displayed, click the HPA Policies tab and then next to the target HPA policy.
  3. In the expanded area, choose View Events in the Operation column. If the policy malfunctions, locate and rectify the fault based on the error message displayed on the page.
    You can also view the created HPA policy on the workload details page.
    2. In the navigation pane, choose Workloads. Click the workload name to view its details.
    3. On the workload details page, switch to the Auto Scaling tab page to view the HPA policies or CustomedHPA policies. You can also view the scaling policies you configured on the Policies page.
    Table 1 Event types and names
    Event Type
    Event Name
    Normal
    SuccessfulRescale
    The scaling is performed successfully.
    Abnormal
    InvalidTargetRange
    Invalid target range.
    InvalidSelector
    Invalid selector.
    FailedGetObjectMetric
    Objects fail to be obtained.
    FailedGetPodsMetric
    Pods fail to be obtained.
    FailedGetResourceMetric
    Resources fail to be obtained.
    FailedGetExternalMetric
    External metrics fail to be obtained.
    InvalidMetricSourceType
    Invalid metric source type.
    FailedConvertHPA
    HPA conversion failed.
    FailedGetScale
    The scale fails to be obtained.
    FailedComputeMetricsReplicas
    Failed to calculate metric-defined replicas.
    FailedGetScaleWindow
    Failed to obtain ScaleWindow.
    FailedRescale
    Failed to scale the service.
Viewing a CustomedHPA Policy
You can view the rules and latest status of a CustomedHPA policy and rectify faults based on the error information displayed.
  2. In the navigation pane, choose Policies. On the page displayed, click the CustomHPA Policies tab and then next to the target CustomHPA policy.
  3. In the expanded area, if the policy is abnormal on the Rules tab page, click Details in Latest Status and locate the fault based on the information displayed.
Editing an HPAor CustomedHPA Policy
An HPA policy is used as an example.
  2. In the navigation pane, choose Policies. On the page displayed, click the HPA Policies tab. Locate the row containing the target policy and choose More > Edit in the Operation column.
  3. On the Edit HPA Policy page, configure policy parameters listed in Table 1.
  4. Click OK.
Editing the YAML File (HPA Policy)
  2. In the navigation pane, choose Policies. On the page displayed, click the HPA Policies tab. Locate the row containing the target policy and click Edit YAML in the Operation column.
  3. In the dialog box displayed, edit or download the YAML file.
Viewing the YAML File (CustomedHPA Policy)
  2. In the navigation pane, choose Policies. On the page displayed, click the CustomedHPA Policies tab, locate the row containing the target policy, and choose More > View YAML in the Operation column.
  3. In the dialog box displayed, copy and download the YAML file but you are not allowed to modify it.
  4. Click the close button in the upper right corner.
Deleting an HPA or CustomedHPA Policy
  2. In the navigation pane, choose Policies. Choose More > Delete in the Operation column of the target policy.
  3. In the dialog box displayed, click Yes.
