Using Third-Party Images
CCE allows you to create workloads using images pulled from third-party image repositories.
Generally, a third-party image repository can be accessed only after authentication (using your account and password). CCE uses the secret-based authentication to pull images. Therefore, create a secret for an image repository before pulling images from the repository.
The node where the workload is running is accessible from public networks.
Using the Console
- Create a secret for accessing a third-party image repository.
Click the cluster name to access the cluster console. In the navigation pane, choose Configurations & Secrets. On the Secrets tab page, click Create Secret in the upper right corner. Set Secret Type to kubernetes.io/dockerconfigjson. For details, see Creating a Secret.
Enter the username and password used to access the third-party image repository.
- When creating a workload, enter a private image path in the format of domainname/namespace/imagename:tag in Image Name and select the key created in 1.
- Set other parameters and click Create Workload.
Using kubectl
- Use kubectl to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
- Use kubectl to create a secret of the kubernetes.io/dockerconfigjson.
kubectl create secret docker-registry myregistrykey -n default --docker-server=DOCKER_REGISTRY_SERVER --docker-username=DOCKER_USER --docker-password=DOCKER_PASSWORD --docker-email=DOCKER_EMAIL
In the preceding command, myregistrykey indicates the key name, default indicates the namespace where the key is located, and other parameters are as follows:
- DOCKER_REGISTRY_SERVER: address of a third-party image repository, for example, www.3rdregistry.com or 10.10.10.10:443
- DOCKER_USER: account used for logging in to a third-party image repository
- DOCKER_PASSWORD: password used for logging in to a third-party image repository
- DOCKER_EMAIL: email of a third-party image repository
- Use a third-party image to create a workload.
A kubernetes.io/dockerconfigjson secret is used for authentication when you obtain a private image. The following is an example of using the myregistrykey for authentication.
apiVersion: v1 kind: Pod metadata: name: foo namespace: default spec: containers: - name: foo image: www.3rdregistry.com/janedoe/awesomeapp:v1 imagePullSecrets: - name: myregistrykey # Use the created secret.
