Resetting a Node
You can reset a node to modify the node configuration, such as the node OS and login mode.
Resetting a node will reinstall the node OS and the Kubernetes software on the node. If a node is unavailable because you modify the node configuration, you can reset the node to rectify the fault.
Notes and Constraints
- To enable node resetting in CCE standard clusters or CCE Turbo clusters, the version must be v1.13 or later.
Precautions
- Only worker nodes can be reset. If the node is still unavailable after the resetting, delete the node and create a new one.
- After a node is reset, the node OS will be reinstalled. Before resetting a node, drain the node to gracefully evict the pods running on the node to other available nodes. Perform this operation during off-peak hours.
- After a node is reset, its system disk and data disks will be cleared. Back up important data before resetting a node.
- If you reset a worker node that has an additional data disk attached on the ECS console, the attachment will be removed. To keep the data, you need to reattach the disk.
- The IP addresses of the workload pods on the node will change, but the container network access is not affected.
- There is remaining EVS disk quota.
- When a node is reset, the backend will make it unschedulable.
- Resetting a node will clear the Kubernetes labels and taints you added (those added by editing a node pool will not be lost). As a result, node-specific resources (such as local storage and workloads scheduled to this node) may be unavailable.
- Resetting a node will cause PVC/PV data loss for the local PV associated with the node. These PVCs and PVs cannot be restored or used again. In this scenario, the pod that uses the local PV is evicted from the node. A new pod is created and stays in the pending state. This is because the PVC used by the pod has a node label, due to which the pod cannot be scheduled. After the node is reset, the pod may be scheduled to the reset node. In this case, the pod remains in the creating state because the underlying logical volume corresponding to the PVC does not exist.
Resetting Nodes in the Default Pool
- In the navigation pane, choose Nodes. On the displayed page, click the Nodes tab.
- In the node list of the default pool, select one or more nodes to be reset and choose More > Reset Node in the Operation column.
- In the displayed dialog box, click Next.
- Specify node parameters.
Compute Settings
Table 1 Configuration parameters Parameter
Specifications
Specifications cannot be modified when you reset a node.
Container Engine
The container engines supported by CCE include Docker and containerd, which may vary depending on cluster types, cluster versions, and OSs. Select a container engine based on the information displayed on the CCE console.
OS
Select an OS type. Different types of nodes support different OSs.- Public image: Select a public image for the node.
- Private image: Select a private image for the node.
NOTE:Service container runtimes share the kernel and underlying calls of nodes. To ensure compatibility, select a Linux distribution version that is the same as or close to that of the final service container image for the node OS.
Login Mode
- Password
The default username is root. Enter the password for logging in to the node and confirm the password.
Be sure to remember the password as you will need it when you log in to the node.
- Key Pair
Select the key pair used to log in to the node. You can select a shared key.
A key pair is used for identity authentication when you remotely log in to a node. If no key pair is available, click Create Key Pair.
- Inherit Password From Image (supported for ECSs or PMs whose OSs are private images)
Retain the password of the selected image. To use this option, ensure that you have set a password for the selected image.
Storage Settings
Configure storage resources on a node for the containers running on it.Table 2 Configuration parameters Parameter
System Disk
Directly use the system disk of the cloud server.
System Component Storage
Select a disk for storing system components.
- Data Disk: added for storing container runtime and kubelet components by default. The disk size ranges from 20 GiB to 32768 GiB. The default value is 100 GiB. This data disk cannot be deleted or detached. Otherwise, the node will be unavailable.
- System Disk: stores CCE resources such as downloaded images, ephemeral storage for containers, and container stdout logs. If the system disk is fully occupied, it will negatively affect the stability of the node.
NOTE:In clusters of v1.23.18-r0, v1.25.13-r0, v1.27.10-r0, v1.28.8-r0, v1.29.4-r0, or later, you can select a disk for storing system components. If CCE Node Problem Detector is used, ensure that its version is 1.19.2 or later.
Data Disk
- At least one default data disk must be added for storing container runtime and kubelet components if System Component Storage is set to Data Disk. This data disk cannot be deleted or detached. Otherwise, the node will be unavailable. This function is available for clusters of a version earlier than v1.23.18-r0, v1.25.13-r0, v1.27.10-r0, v1.28.8-r0, or v1.29.4-r0.
- If System Component Storage is set to System Disk, you do not need to add a default data disk. In this case, all data disks are common ones: You can set the data disk size to a value ranging from 10 GiB to 32768 GiB. The default value is 100 GiB. This function is available for clusters of v1.23.18-r0, v1.25.13-r0, v1.27.10-r0, v1.28.8-r0, v1.29.4-r0, or later versions.
Click Expand to configure Data Disk Space Allocation. This allocates space for container engines, images, and ephemeral storage to ensure their proper running. For details about how to allocate data disk space, see Space Allocation of a Data Disk.
For other data disks, a raw disk is created without any processing by default. You can also click Expand and select Mount Disk to mount the data disk to a specified directory. Data disks can also be used as local PVs or local EVs.
Advanced SettingsTable 3 Advanced configuration parameters Parameter
Resource Tag
You can add resource tags to classify resources. A maximum of eight resource tags can be added.
You can create predefined tags on the TMS console. These tags are available to all resources that support tags. You can use these tags to improve the tag creation and resource migration efficiency.
CCE will automatically create the CCE-Dynamic-Provisioning-Node=Node ID tag.
Kubernetes Label
Click Add Label to set the key-value pair attached to the Kubernetes objects (such as pods). A maximum of 20 labels can be added.
Labels can be used to distinguish nodes. With workload affinity settings, container pods can be scheduled to a specified node. For more information, see Labels and Selectors.
Taint
This parameter is left blank by default. You can add taints to configure anti-affinity for the node. A maximum of 20 taints are allowed for each node. Each taint contains the following parameters:- Key: A key must contain 1 to 63 characters, starting with a letter or digit. Only letters, digits, hyphens (-), underscores (_), and periods (.) are allowed. A DNS subdomain name can be used as the prefix of a key.
- Value: A value must contain 1 to 63 characters, starting with a letter or digit. Only letters, digits, hyphens (-), underscores (_), and periods (.) are allowed.
- Effect: Available options are NoSchedule, PreferNoSchedule, and NoExecute.
NOTICE:- If taints are used, you must configure tolerations of pods. Otherwise, a scale-out may fail or pods cannot be scheduled onto the added nodes.
- After a node pool is created, you can click Edit to modify its configuration. The modification will be synchronized to all nodes in the node pool.
Max. Pods
Maximum number of pods that can run on the node, including the default system pods.
This limit prevents the node from being overloaded with pods.
Pre-installation Command
Installation script command, in which Chinese characters are not allowed. The script command will be Base64-transcoded. The characters of both the pre-installation and post-installation scripts are centrally calculated, and the total number of characters after transcoding cannot exceed 10240.
The script will be executed before Kubernetes software is installed. Note that if the script is incorrect, Kubernetes software may fail to be installed.
Post-installation Command
The script will be executed after Kubernetes software is installed, which does not affect the installation.
- Click Next: Confirm.
- Click Submit.
Resetting Nodes in a Node Pool
- When resetting a node in a node pool, you can only change its storage configuration. All other configurations will follow the settings of the node pool.
- Resetting a node will execute the pre- and post-installation scripts in the current node pool and update the security group configurations to those of the node pool.
- In the node list of the target node pool, select a node to be reset and choose More > Reset Node in the Operation column.
- Modify the node storage parameters.
Table 4 Configuration parameters Parameter
System Disk
Default Data Disk
Select a data disk for container runtime and kubelet.
Data Disk
Configure advanced settings for each data disk.
For the default data disk, click Expand to configure Data Disk Space Allocation. This allocates space for container engines, images, and ephemeral storage to ensure their proper running. For details about how to allocate data disk space, see Space Allocation of a Data Disk.
For a common data disk, click Expand and configure mount options.
- Default: The data disk is attached as a raw disk without any settings.
- Mount Disk: The data disk is attached to the service directory path. This parameter cannot be left blank or set to a key OS path such as the root directory.
- Use as PV: The data disk is used as persistent storage volumes for PVCs. For details, see Local PVs.
- Use as ephemeral volume: The data disk is used as ephemeral storage volumes for PVCs. For details, see Local EV.
- Click OK.
Resetting Nodes in a Batch
Resetting nodes in a batch varies depending on application scenarios.
Scenario |
Supported or Not |
Description |
Resetting nodes in the default pool in a batch |
Conditionally supported |
This operation can be performed only if the node flavor, AZ, and disk configurations of all nodes are the same. |
Resetting nodes in a node pool in a batch |
This operation can be performed only if the disk configurations of all nodes are the same. |
Resetting nodes in different node pools in a batch |
Not supported |
Only the nodes in the same node pool can be reset in a batch. |
