El contenido no se encuentra disponible en el idioma seleccionado. Estamos trabajando continuamente para agregar más idiomas. Gracias por su apoyo.
On this page
Restrictions and Compatibility
Note the following restrictions and compatibility issues when importing or exporting APIs on APIG:
Restrictions
  • APIG parameter restrictions:
    • APIG does not support the configuration of request parameters in the formData and body locations.
    • APIG does not support the configuration of parameters consumes and produces.
    • The names of header parameters are not case-sensitive.
  • Backend policy restrictions are as follows:
    • Default backend type HTTP: The HTTP and HTTP-VPC backends are supported.
    • Default backend type HTTP-VPC: The HTTP and HTTP-VPC backends are supported.
    • Default backend type function: Only the function backend is supported.
    • Default backend type mock: Only the mock backend is supported.
Compatibility
  • OpenAPI is supported.
    The OpenAPI Specification (OAS) defines a standard, language-agnostic interface to RESTful APIs. OAS is formerly known as Swagger. APIG supports two OpenAPI specifications: Swagger 2.0 and OpenAPI 3.0. For easy understanding, in the following sections, OAS refers to OpenAPI Specification (including Swagger 2.0 and OpenAPI 3.0), Swagger refers to Swagger 2.0, and OpenAPI refers to OpenAPI 3.0.
  • Mappings between imported or exported OAS objects and APIG's objects
  • Differences in request parameter types
  • Differences in API request path template syntax
  • Extended fields supported for APIG when importing APIs
Table 1 Mappings between OAS objects and APIG's objects
Swagger Object
OpenAPI Object
(3.0.0)
APIG Object
Import
Export
info.title
info.title
API group name
Importing to a new API group: a new API group name
Importing to an existing API group: not used
An API group name consists of 3–64 characters, starting with a letter. Only letters, digits, and underscores (_) are allowed.
API group name
info.description
info.description
API group description
Importing to a new API group: description about the new group
info.version
info.version
Version
Not used
User-defined version
The current time is used as the API group name if no name is specified.
host
server.url
API group domain name
Not used
The first user-defined domain name of an API group is preferentially used.
The independent domain name of the API group is used if the API group is not bound with any user-defined domain names.
basePath
Merged with the request path of each API
Not used
paths.path
paths.path
API request path
Merged with basePath to use as an API request path
API request path
operation.operationId
API name
API name
API name
operation.description
API description
API description
API description
operation.parameters
API frontend request parameters
API request parameters
operation.schemes
API frontend request protocol
API request protocol
operation.responses
operation.responses
Not used
Default response
operation.security
operation.security
API authentication mode
Used together with x-apigateway-auth-type
Table 2 Differences in request parameter types
OAS
APIG
Supported Attribute
integer
long
float
double
number
maximum
minimum
default
enum
required
description
string
string
maxLength
minLength
default
enum
required
description
Other
None
None
Table 3 Differences in API request path template syntax
Syntax
OAS
APIG
/users/{userName}
Supported
Supported
/users/prefix-{userName}
/users/{userName}-suffix
/users/prefix-{userName} -suffix
Supported
Not supported for frontend request definition
Supported for backend request definition
/users/{proxy+}
Not supported
Supported for frontend request definition
Not supported for backend request definition
Utilizamos cookies para mejorar nuestro sitio y tu experiencia. Al continuar navegando en nuestro sitio, tú aceptas nuestra política de cookies. Descubre más
