El contenido no se encuentra disponible en el idioma seleccionado. Estamos trabajando continuamente para agregar más idiomas. Gracias por su apoyo.
Kafka Log Push
Kafka log push policies push calling logs of open APIs to Kafka for analysis.
If your gateway does not support this policy, contact technical support to upgrade the gateway to the latest version.
Usage Guidelines
Configuration Parameters
Table 1 Parameter description
Policy Information
Broker Address
Connection address of the target Kafka. Separate multiple addresses with commas (,).
Topic
Topic of the target Kafka to report logs to.
Key
Partition of Kafka for storing logs as an ordered message queue. If this parameter is left blank, logs are stored in different partitions.
Retry
Configuration for retrying when logs fail to be pushed to Kafka.
  • Retry Times: the number of retry attempts in case of a failure. Enter 0 to 5.
  • Retry Interval: the interval of retry attempts in case of a failure. Enter 1 to 10 seconds.
SASL Configuration
Security Protocol
Protocol used for connecting to the target Kafka.
  • PLAINTEXT: user authentication protocol of the default access point
  • SASL_PLAINTEXT: SASL user authentication protocol
  • SASL_SSL: SSL user authentication protocol
Message Tx/Rx Mechanism
Message transmission and receiving mechanism of the target Kafka. The default value is PLAIN.
SASL Username
This parameter is available only if Security Protocol is set to SASL_PLAINTEXT or SASL_SSL.
Username used for SASL or SSL authentication.
SASL Password
User password used for SASL or SSL authentication.
Confirm SASL Password
Enter the SASL password again.
Certificate Content
This parameter is available only if Security Protocol is set to SASL_SSL.
CA certificate used for SSL authentication.
Metadata Configuration
System Metadata
System fields that need to be included in pushed logs.
By default, the start_time, request_id, client_ip, request_time, http_status, scheme, request_method, host, uri, upstream_addr, upstream_status, upstream_response_time, http_x_forwarded_for, http_user_agent, and error_type fields are carried in logs. You can also specify other system fields that need to be included.
Request Data
API request information that needs to be included in pushed logs.
  • The log contains the request header: Specify a header that needs to be included. Separate multiple headers with commas (,). The asterisk (*) can be used as a wildcard.
  • The log contains the request QueryString: Specify a query string that needs to be included. Separate multiple query strings with commas (,). The asterisk (*) can be used as a wildcard.
  • The log contains the request body: If this option is selected, logs will contain the body of API requests.
Response Data
API response information that needs to be included in pushed logs.
  • The log contains the response header: Specify a header that needs to be included. Separate multiple headers with commas (,). The asterisk (*) can be used as a wildcard.
  • The log contains the response body: If this option is selected, logs will contain the body of API request responses.
Customized Authentication
Custom authentication information that needs to be included in pushed logs.
  • Frontend: Enter a response field of frontend authentication that needs to be included. Separate multiple fields with commas (,).
  • Backend: Enter a response field of backend authentication that needs to be included. Separate multiple fields with commas (,).
Utilizamos cookies para mejorar nuestro sitio y tu experiencia. Al continuar navegando en nuestro sitio, tú aceptas nuestra política de cookies. Descubre más
