Viewing Metrics
Cloud Eye monitors the status of your APIs and allows you to view their metrics.
Viewing Metrics of an API
- Go to the APIG console.
 - Select a gateway at the top of the navigation pane.
- In the navigation pane, choose API Management > API Groups.
- Click a group name.
 - In the left pane of the APIs tab, select an API.
- View metrics of the API in the Monitoring area.
View the call statistics of an API, including Requests, Latency (ms), Data Traffic (bytes), and Errors. You can also select a time range to view the data.
- Data in the last hour is updated every 2 minutes.
 - Data in the last 6 hours is updated every 2 hours.
 - Data in the last day is updated every 2 hours.
 - Data in the last week and last month is updated every day.
 - To view monitoring information about instances and instance nodes, click More.
     The monitoring data is retained for two days. To retain the data for a longer period, save it to an OBS bucket.
Viewing Metrics of an API group
- In the navigation pane, choose Monitoring & Analysis > API Monitoring.
 - Select the API group to be viewed and view the API call statistics, including Requests, Latency (ms), Data Traffic (bytes), and Errors
